Old 01-28-2014, 07:43 PM   #163
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Been awhile since I was on YW and I come back to my favorite subject, Yaris towing.
I use a Curt Class 1 Sport hitch on my Yaris and moved from WV to GA towing a 1900 pound U-Haul trailer. The experience was not one I would recommend, it took some getting used to and despite my best efforts I did jackknife during an emergency stop on the interstate. I do however regularly tow my ATV and trailer weighing in at around 700lbs together with little effort.
The record for my towing? 6 miles over rolling hills including an on hill start towing a 2005 F150 FX4 weighing in at around 7300 pounds.
I am still on my original clutch at 140k miles and would consider 1000lbs within the realm of feasible towing on the Yaris. I would recommend an aftermarket intake of some sort however, it doesn't seem like much but the difference for me was a lot less downshifting on small highway hills.
I have attached a couple pictures I had on my pc of different towing with the yaris I have done, The one with my wifes scooter was also loaded down in the back to the max with the trip being just over 1k miles.
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 07-03-2014, 04:54 PM   #164
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Originally Posted by Bluevitz-rs View Post
Amen sister!
First of all, I am a Very LARGE DUDE!
and for the guy who thinks an FX4 F150 weighs 7300 Lbs,
ONLY if it had 1700+ Lbs of crap in the Box or Cab...My 2004 Reg Cab Long Box weighs 5000Lbs, My Brother's 2005 SuperCrew 5.5 box 5300Lbs...These are the New Style w/box frame like in your Photo.
But needless to say I am not afraid of towing with my Auto Equipped Yaris....Up to 1000Lbs
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 07-07-2014, 12:27 PM   #165
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I did it again. This time with a bigger trailer and wet material. Trailer is totally bottomed out too and I put on my stock springs in the rear to carry the extra weight. Though it doesn't look like it LOL.
Sent from my iPod Touch
Old 05-28-2015, 12:48 PM   #166
Koco
Drives: 2007 Yaris 2 dr 5spd Hatchback
2000lb trailer for yaris YIKES!
These companies selling 2000lb trailers are totally !
BEWARE! I am moving Houston to Western Mass and was looking into a small uhaul trailer rental with high hopes. Of course I took a look at my owners manual and found:
Vehicle capacity weight
(occupants + luggage)
kg (lb.) 383 (845)
Towing capacity∗3
(trailer + cargo weight)
kg (lb.) 318 (700)
∗1: With P175/65R14 81S tires
∗2: With P185/60R15 84T tires
∗3: For Canada only
Not sure about the Canada only note.
I'm sure its safe to tow small items and I think a hitch could be convenient addition. Stay safe ya'll!
Koco is offline   Reply With Quote
Old 06-17-2015, 08:20 PM   #167
DianaLyn
Drives: 2010 yaris
Smile Hoverlift by Hoverround
I am handicapped but can still drive. It saddens me to read these post. I want to by hoverlift, but not for my hoverround wheelchair. I have a foldup that weights 48#. it won't fit in the trunk. So, the hoverlift wt. is 80#, Swing arm is 40#, and my chair is 48#. Total 168#. Hoverlift is not a trailer. I don't see why I couldn't use this. What is your opinions? Thank you
DianaLyn is offline   Reply With Quote
Old 06-17-2015, 08:41 PM   #168
168 lbs on a hitch rack type device will be fine. I have a hitch mounted basket that I use to haul my trash cans to the dump/recycling center. I ofter have loads that are in excess of 150 lbs and I don't even feel line anything is back there.
Old 08-17-2015, 03:33 PM   #169
Ataristyle
Drives: 2011 5dr 5spd LB
Here's something to share. Picked this up end of last year. Its around 1,300 lbs. Just started to go through reconstruction phase with it. Its in desperate need of help. It was towed 50 miles back home and no problems along the way. It honestly felt great behind the Yaris. I had spotter vehicles in front and back of me incase something went wrong. It was sitting for a real long time and wood has lots of rot. Was just hoping it stayed in one piece to make it home which it did. :-) I feel comfortable to pull it again if I have to. However, because most likely I will be loading it up for camping, I will use a truck to get this task done. Gave into buying Truck so it will handle this very easy. I will use the yaris to haul locally if needed since I know the terrain and trailer won't be loaded up for that use. Be Safe!
Ataristyle is offline   Reply With Quote
Old 12-21-2015, 07:59 PM   #170
jayeh
Drives: '08 Yaris LB
Anyone investigated adding a transmission temperature gauge?
jayeh is offline   Reply With Quote
Old 01-18-2016, 01:06 PM   #171
Ataristyle
Temp gauge not needed on the manual transmission but will admit if my car was automatic I would not use it to tow.
Old 01-18-2016, 05:22 PM   #172
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Here in Australia my third gen Yaris manual lists maximum towing load as 900kg (1984 pounds) with trailer brakes, or 500kg (1216 pounds) without trailer brakes.
The manual also recommends not using 5th gear on a manual transmission and leaving an auto transmission in "3" while towing. This is to maintain engine braking and electrical charging efficiency...
The same limits are applied for both the 1NZ-FE and 2NZ-FE engines.
kevinj93 is offline   Reply With Quote
Old 01-18-2016, 10:51 PM   #173
jayeh
Electrical Charging Efficiency?
Old 01-19-2016, 03:52 PM   #174
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Exact wording from the manual is:-
"To maintain engine braking efficiency and charging system performance when using engine braking, do not use the transmission in D (vehicles with an automatic transmission) or 5 (vehicles with a manual transmission)."
I may have misread this, it might only refer to times when using engine braking.
I think the idea is that there will be an additional load on the electrical system from the trailer lights. Here, large trailers (not sure of the exact size) and caravans are required to have additional "clearance lights" showing the width, length and height of the trailer, which would add additional current requirements at night.
Old 08-23-2016, 03:58 PM   #175
jayeh
So, speaking of towing...
My Yaris hauled a 4x4 utility trailer from Ontario to B.C. without any issues. 4500 KM via the Canada route. Took it easy, I don't think I went over 107 kph the entire time and everything went fine. Still kind of surprised how such a tiny engine could still be pretty peppy uphill!
Old 09-16-2016, 09:07 AM   #176
haro
Newbie
Drives: Black YRS
Sent from my D5503 using Tapatalk
haro is offline   Reply With Quote
Old 09-17-2016, 10:16 PM   #177
Bluevitz-rs
Awesome!
Old 01-08-2017, 01:28 AM   #178
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
I am looking to install a hitch, either Curt or Hidden. Do either of those require to cut the body to fit? The lady at the trailer place told me that in order to put a hitch on the back they had to cut bumper no matter which hitch I used. Is this true? I thought the Hidden hitch fits underneath the bumper?? Please help, I need to pick up my trailer next week and need something installed soon!
jeeper5usa is offline   Reply With Quote
Old 01-08-2017, 06:41 AM   #179
ardvark2175
ardvark
Drives: 2012 Yaris LE
I installed hidden hitch on my 2012 Yaris. You DO NOT have to cut into bumper. It goes Underneath.
Sent from my ONE A2005 using Tapatalk
ardvark2175 is offline   Reply With Quote
Old 01-11-2017, 08:38 PM   #180
billfires
Drives: 2010 3dr LB
I put a Curt hitch on my 2010 HB and did not have to cut anything. Bill
billfires is offline   Reply With Quote
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
