Old 06-24-2015, 01:51 PM   #163
nookandcrannycar
Originally Posted by trini_per4mance View Post
Why did you replace the shifter cables?
Sent from my SAMSUNG-SM-N910A using Tapatalk
You are our 'holy grail' when it comes to mileage and longevity for original owners (and even for original engines)!
Currently, how high is 'the summit'...how many miles on your Yaris ?
Old 06-25-2015, 07:29 AM   #164
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Thank you! I currently have roughly a measly 543,000 miles on my Yaris. This may sound crazy to the average person out there, but I'm going to turbocharge it in the near future. My Valve Seals have now started to leak when I run thru the RPM's. So, I'm burning oil and have to top it up about every 1000 miles.
You never answered my question as to why you changed your shifter cables... Lol. I'm really interested to know why and if it fixed your problem. Bcuz currently I have a rattling noise from my linkage on my gearbox. But when I pull or push the shifter towards any gear while in neutral (which I'm basically put tension on the shifter cables by doing that), the noise goes away. So, I was thinking that maybe I should change out my cables too. Let me know what your issue was with your cables.
Thanks!
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 06-25-2015, 09:35 AM   #165
nookandcrannycar
Thanks!
Thanks for the reply to my post ! Sorry, I'm not the member who changed his shifter cables . You are quite an inspiration, so members like to hear about your current odometer mileage (...and putting on many fewer miles than you used to doesn't change that curiosity) and what you are currently doing with your Yaris . This has come up on threads since you last posted . Some of us know we can check your maintenance/repairs and mods on your '500,000 miles on my Yaris' thread. Post #1 on that thread shows the mileage interval that you did repairs/major maintenance, and mods, but doesn't hint to a current odometer level (last update to that page - January 2014). I don't think it's crazy that you're going to turbocharge your Yaris at 543,000 + miles . Given your maintenance intervals, etc., I'd imagine there isn't a 500,000 mile plus Toyota anywhere in the States that is in better condition than yours. Definitely update post #1 on your '500,000 miles on my Yaris' thread after you install the turbo setup (and create a thread foe thgat as well if you are so inclined ). I hope the member who changed his shifter cables answers your question.
Old 06-25-2015, 12:37 PM   #166
coheed
Drives: 08 BB LB
It was a very odd situation. I went out to drive my car one morning and I could only shift 3-4. The side to side cable had seized up . Mind you this was the first year I had owned the car with roughly 30k on the odo. Not sure what was wrong, or what caused it, but they set me back $287.
Old 04-24-2016, 02:30 AM   #167
bairjo
Well I'm in the club...103,000 miles on my 2010. No issues here. Guess I should change the oil now...lol.
Old 05-02-2016, 12:00 PM   #168
billfires
Drives: 2010 3dr LB
Just turned 100,000 on my 2010 HB. Oil & filter changes, air filter and tires have been the only maintenance items. Bill C
billfires is offline   Reply With Quote
Old 05-02-2016, 12:56 PM   #169
texascolt45
Drives: 2015 yaris
I got 15,000 since august of last year.
texascolt45 is offline   Reply With Quote
Old 05-02-2016, 01:53 PM   #170
bairjo
15,000....Congratulations. .....You are almost there.
Old 05-06-2016, 06:13 PM   #171
jose1969
Drives: yaris d4d
Hi there!
I'm just getting 100000 miles on my '08 yaris d4d in few days....no problems until now
Edit: yesterday the battery just said goodbye and the check engine light is in the dashboard.
jose1969 is offline   Reply With Quote
Old 05-08-2016, 06:11 PM   #172
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I hit 102k on the chassis recently on my 07 sedan.
Sent from m-o-b-i-l-e
Old 06-14-2016, 01:15 PM   #173
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
I'm at 253k right now... I'm starting to wonder if I should proactively swap the alternator, fuel pump, or water pump? I have a 75 mile each way commute into town and don't want to get stranded. Car drives perfectly though!
Cosmetically my front end has been chipped all to hell by all the construction around Atlanta. I'm planning on having the front end totally repainted and using Xpel on the front. Nothing else has really taken a beating like the front... the damned main road through the city was practically a gravel for a few weeks!?!?!
firebird1999us is offline   Reply With Quote
Old 06-14-2016, 10:12 PM   #174
CB900F2
Drives: 08 Sedan
170,000Km on my 2008 Sedan... And runs and looks like a champ!..
CB900F2 is offline   Reply With Quote
Old 06-18-2016, 10:54 AM   #175
zoidberg444
zoidberg444's Avatar
110,000 miles roughly on my 06 jap made Hatchback. Pretty impressive considering mine has the 3 cylinder engine made for the Aygo in it. I really don't think Toyota designed it for being driven like its stolen every day.
Servicing, tyres, exhaust, water pump, battery and oddly enough my alternator. Its never once let me down, always done whats needed from it until i could get it to a garage. I also have a little noise that sounds like the thrust bearing might be starting to wear. But I'll wait till it gets worse to do the clutch.
I intend to drive it until it collapses into a pile of rust. If the engine blows up i will just stick a used one in.
Old 06-19-2016, 01:57 AM   #176
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
I wish we got the funky little Aygo in the US. We don't get any of the kewl small cars.
BLKHILLSGUY is offline   Reply With Quote
Old 06-19-2016, 03:47 AM   #177
Tapokata
Drives: 2009 Yaris
154K on my 09 LB Clown-car. No issues other than normal service. Synthetic oil since first change, and extended drain interval (15K miles) since from 45K miles onward. No oil consumption. The 1NZ-FE is durable, and damn near bulletproof.
Tapokata is offline   Reply With Quote
Old 06-19-2016, 04:36 AM   #178
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Just curious but did you do any used oil analysis? And what brand of oil are you using?
Old 06-19-2016, 10:05 AM   #179
Captain Yaris
Captain Yaris's Avatar
Drives: 2016 Yaris 3 Dr Super White
7500 miles in 3.5 months, I'm well on my way to join the club. I'm planning on switching to synthetic after 12,000 miles. I have to say, I love this little car!
Captain Yaris is offline   Reply With Quote
Old 10-22-2016, 08:51 PM   #180
BennyLava
Drives: 1987 Silverado
Where's the 300k mile club? That would be pretty cool to have. If well maintained, I don't see why these cars couldn't go 350k or more.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 01:40 PM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 06:51 PM
Japanese Mix Club Los Invitamos!!! TunTun_yariS[PR] Caribbean 0 12-12-2006 01:03 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
