Drives: 2007 Yaris LB Join Date: Mar 2007
Aux Port for MP3/iPod Players
Does anyone else have this problem? When I plug in my iPod, I can hear the music on my Yaris sound system, BUT the sounds is kind of staticy, like listening to a cheap cassette copy of an album....I have to twist the jack randomly before the sound improves. This happens about 50% of the time I use the Aux jack. The iPod works perfectly by the way, so I don't know what to make of this. I just got my 2007 LB a few days ago.
Anyone have any ideas? Thanks! |
- Donnie Demonic -
Drives: '07 Yaris Sedan Sport Join Date: Oct 2006
Unless the volume is too low on your iPod and too high on your car stereo, I'd say it was the quality of the mp3 on your iPod.
#3 | |
Now if I tweek the cable which is plugged into the jack the sound often improves...could it be that my aux jack is jacked up? No pun intended....lol |
Yes, you have a bad cable. I have a bad cable in one of my cars and it does the same thing.
Drives: 2007 Toyota Yaris 4dr Join Date: Mar 2007
I had that problem with my XM Radio. I bought a groundloop isolator and it fixed it.
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
theres a grounding issue with stereo/input....
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
I bought my Yaris in Greece and I have no Aux in...
As you can see... ![]() ![]() Perhaps there is a solution.. There is something downthere! ![]() Is this "plug" for the Aux in? Thank you!
Chances are, yes. I'm guessing that when built all LB have the same wire loom. It's just a matter of if anything is plugged into the plugs. IMO the AUX input is overated. For one the volume level sucks. I can just as easily burn a few cd's and have a ton of music at my finger tips.
Yes that is right... That is what I do also...
But I was wondering. . . I wanted to have it to!
![]() Drives: 2008 Yaris Join Date: May 2010
Was it ever found out if this is the aux cable? I have the same plug as the picture above loose in my 2008 Yaris.
Thanks |
Drives: 2007 Yaris D4D Join Date: Jun 2015
Sorry...but i also need to know the answear...
Bump! |
Well, my thoughts on the subject is this. The plug is facing straight up and the cover on mine is open a lot of times. It is very possible you could have some dirt and gunk down in there which would give you the same symptom as a bad cable. There are electronic cleaning sprays you squirt down in there to clean it up that are fast drying. Can't hurt to try that.
| Toyota AUX plug w/ aftermarket radio? | eight_heads | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 09-07-2007 02:41 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
| What type of head unit with AUX port? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 11-06-2006 10:21 AM |
| US LB stock CD/MP3/WMA player... Extra AUX jacks? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-08-2006 02:29 AM |
| Where's my AUX adapter??? | yaris-intuit | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 08-21-2006 09:54 PM |
