![]() ![]() ![]() Drives: Gray Join Date: Jun 2012
Apple Cider Vinegar Rust Inside the car
I've been putting rags of apple cider vinegar throughout the car for three months due to, if you've read my squirrel problem thread. I've noticed that rust is forming in areas, I have decided to stop doing this but with some elbow grease it comes off, but some areas are extremely hard to remove. Can this cause damage to areas that I can't remove to the car ? Can it get though the carpet of the car ?
As for the squirrel problem; I'm planning on finding a solution, if I can find a solution, until I move which is the best solution ! |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
I'm not sure where you are putting this vinegar, but I believe vinegar is highly acidic, thus your problem with rust.
remind me what the problem with using a trap was again?
Refusal to believe that it may just actually work.
In the mean time...
Location of where I am; doesn't permit putting traps. That is why I can't use traps, otherwise I may get fined since some know I'm the one with the problem, the likelihood is good I'd get a fine.
All the steel parts in the car are oxidized, simply wiping with even saliva it comes off, problem is, there are many hard to reach areas that I can't get to. If I could DE-oxidize the air and it would fall off, that would be great. |
