![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
jacking up the car
Anybody ever lift the car using floor jacks under the control arms? Will that damage the control arms ? kinda like where I have the red arrow at in this picture?
やりすぎだ~
Not where you put the arroow, but on my Echo because the underbody is so rusted I jack up just under the subframe. I then place jacks on the sides behind the wheels.
I have done this for the past 2 years with no issues, I just do so carefully. I have also jacked the control arm up to put weight. On the suspension when I replaced the end links. I did this when they car was resting on jacks under the sides. |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
Likely you'll bent it. Not a good call.
Not a problem it's fine do it all the time on alignment rack and no u won't bend ur control arms.
Sent from my ASUS_Z00AD using Tapatalk |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
^ Big lady says no... no. no. no..
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
thanks
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Closer to the balljoint, but yes it is fine to lift there. Just be aware that the ctrl arm can angle when jacking. If your jack-pad is steel, it may slip off so watch that. I prefer to jack on the subframe bolts etc.
Cheers. |
![]() ![]() ![]() Drives: 1986 Toyota Corolla Join Date: May 2009
Is there a reason why you aren't using the usual lift spot? Like Cory stated, the control arm is a pivoting piece and will move as you're lifting, which is why most people don't do it
jacking up
just checking my options, but I believe using the subframe is a better place to jack up the car. thank y 'all for the replys
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 04:19 AM |
| Car Buying Scams | nemelek | Off-topic / Other Cars / Everything else Discussions | 1 | 09-29-2011 08:01 PM |
| thewifesyaris - photo scavenger hunt | thewifesyaris | Photo-Video-Media Gallery | 0 | 03-01-2009 06:02 PM |
