Old 06-30-2015, 09:46 PM   #1
josephangel00
Drives: 2007 toyota yaris
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Hello everyone , I have a 2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air . The compressor and clutch are running and I know the car has freon. I do see stuff coming from the ac vents. Any idea's? What troubleshooting can I try? Sometimes the car sporadically sprays cold air. Could this be a fuse or thermostat? Also the fan in front of the ac condensor goes on and off randomly, does this have anything to do with it?
josephangel00 is offline   Reply With Quote
Old 07-07-2015, 12:27 PM   #2
esse10
Drives: 2009 yaris 2 door
blowing stuff out the vents
You say the vents are blowing stuff out? foam? If it's foam than most likely it's the blend door foaming gone bad. warm air from heater is mixing with the cold in evaporator causing you issues. The condenser fan going off does have something to do with it but it's probable going off cause the A/C system is turning off .
Old 07-07-2015, 06:29 PM   #3
The condenser fan turning on and off is normal. The system may either not be properly charged (too much or too little freon) or the pressure switch, which is mounted to the aluminum tubing by the sight glass, may be bad.
Injen Cold Air Intake fit Toyota Yaris Daddie Y Items for Sale by private party 5 02-13-2015 02:24 PM
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
