![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
Fram oil filters
Hi folks...
I've used these filters for years now and I have no issues so far, however, i've been told that those are the worst filters ever, but want to make sure I am not doing a long term damage to the engine by using it.
20 years... alive and kickin'!! ![]()
![]() Drives: 2008 Yaris Base Join Date: May 2014
I think it depends on the oil change intervals. 3,000 to 5,000 mile intervals should be okay. But there are better alternatives like Denso or Purolator. I use the DENSO 150-1000 oil filter and it is the same as OEM Toyota but has better filtration media, silicone anti drain back valve and more durable housing.
Mr. 155 and climbing
Personally I would never use a Fram filter. You can Google and find al sorts of information on them. The only filters I have used for 5 years are from Amsoil or Mann and they have been great. Denso as well is a solid choice as it is the OEM filter.
Sent from my SCH-I545 using Tapatalk
Denso First Time Fit
![]() Toyota OEM ![]() Fram
![]() ![]() ![]() Drives: 2007 Yaris 5 door RS Join Date: Nov 2014
Some have found defective Fram filters (eg: The media isn't stuck together right out of the box), but we'll ignore those as they are the minority. What is normal with the cheap Frams (not the higher end ones) is that the filter ends are made of cardboard. This seems like (to most people) a bad idea since cardboard likes to dissolve in liquid. Other companies typically crimp with steel. Also the drainback valve design on Fram filters can be poor. These issues can, in some unusual circumstances, lead to the filter collapsing.
That being said, there's many who have used their filters without issues for decades. I only use Fram filters when they are significantly cheaper, because they are built like a cheap discount filter, they should be sold at that price. However, sometimes Fram filters are sold at "normal" prices, in which case, why buy not just buy something made better for the exact same price? Only in one circumstance would I flat out refuse to use a Fram filter: If I were trying to minimize the number of oil changes I have to do. If I were using synthetic oil to try to get those crazy 10,000+ mile oil changes some people do, I think a discount filter is a very bad idea! |
I've never had issues with fram filters, but they have ends made of cardboard, this is an issue when comes reliability.
Sent from my A0001 using Tapatalk |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Fram = cheap!!! It's a hit and miss!!!
No thanks for me. |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Mobile1....blows them all away in capicity and quality. As for fram, you may as well put a roll of toilet paper in a a coffee can with an adapter to the oil filter threads.....
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
Used Fram on my last oil change, not a fan after hearing an odd taping on warm idle(after about 1500miles). Back to the OEM filter, noise is gone. Used Mobil 1 before, that filter was absolutely bad ass, 5K miles and the oil was clear just like when i first put it in.
If your wallet allows, try out Mobil 1 and go for 7k+ intervals with full synthetic. |
FRAM filters look crudely made to the general public, but they are tested in a lab to work. If they resulted in engines that wore out prematurely by this time they would be out of business.
Strangely they cost more than Purolator filters! ![]() As long as you aren't going 10,000 miles between oil changes I think youll be fine.
#11 | |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
I've been using Denso (or Mann). Never saw the first time kit.
There is a number ( Denso 150-1006?) which is for the Yaris. Since all the filters must meet SAE specs, I would be surprised to see a problem, as long as they are used as intended. I would opt for a better filter if I was running the car hard. Also I have the magnetic drain plug. |
#13 | |
And that's an aircooled engine. Cheap oil filters for me!
#14 |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
I use PureOne oil filters because I change engine oil every 5k miles. It is cheaper than mobile1 and the construction materials are on par with mobile1 (Metal end caps , silicon ADBV etc).
#15 | |
#16 |
Isn't that a boxer engine? So a very different design than our cars with variable valve timing and such that can be damaged from particulates in the oil hence the reason for the oil filter.
#17 |
Thanks for the feedback folks, I'll return to denso/oem filters and keep you posted.
#18 | |
I would argue the fact that ALL the bearings were still in spec after 250k miles and NO oil filter means the modern features of our Yaris's engine wont be damaged either. And lets remember the FRAM filters are laboratory tested to a standard for modern cars. They meet the same standards as every other filter in their class for effectiveness and durability, no matter their dubious looking construction. The notion that FRAM filters aren't up to snuff is a conclusion of non engineers with no lab to test oil filters and no experience in that field. And then theres this. After around twelve years and ~125k miles the engine may be doing just fine but the rest of the car is a decade out of style and modern safety and convenience features. For a lot of people that means new car time...
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 03:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
