Old 10-17-2014, 07:43 PM   #19
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Bump, Scott?
Old 10-17-2014, 07:44 PM   #20
Originally Posted by Betrivent View Post
Oh, one more thing: could I ground it to the power mirror wires? That way I only have to run one wire through my door to the electrical panel right?
Possibly. You would have to check to see how good the continuity to ground is for the door.
Old 02-19-2015, 04:58 PM   #21
bairjo
On an 09+, the wires are already there between the power mirror connector and the kick plate connector on both sides, so on the mirror side you would just have to snake a wire through the mirror mount and connect it to either a set of OEM heated mirror glass pieces or a set of the stick on aftermarket mirror heaters. On an 08- you'd have to run the wire all the way from the mirror, through the door and into the kick plate area.
CTScott, I am doing this install on my 2010. I have the door panel off and the three wires for the power mirror, black red and white, channel down and plug into a plug in the door. This plug they plug into also has a light blue and a purple wire leading into it. Are these the heating element wires? If so , just wire my leads from the element in the mirror directly into these?
bairjo is offline   Reply With Quote
Old 02-19-2015, 10:43 PM   #22
Those two wires are for the OEM mirror heaters. They only go as far as the connector at the kick panel.
Old 02-19-2015, 10:51 PM   #23
Kar98
Drives: 2011 Scion tC
Fan speed to 3 or 4, recirc air, direction selector all the way to the lower right (windshield), heat set to full blast, dash vents open and pointed to the triangle windows... and the mirrors clear up just as fast as any of the cars with heated mirrors I've had before (Golf III, Scirocco II, BMW 2 series).
Enough ice that neither this, nor some de-icer spray can deal with, heated mirrors are a lost cause as well, because they're very low powered.
Kar98 is offline   Reply With Quote
Old 02-19-2015, 11:49 PM   #24
bairjo
I understand now...thank you. By the way my mirrors do pop off like the ones in the link you provided above but are not glued in place. They snap into the frame with a little sticky putty in back of them. I will be posting a video of my install if anyone is interested.
Old 02-20-2015, 12:02 AM   #25
bairjo
Shit.... for that matter if you blast the rear window long enough with the air from the vents above the radio you don't need it as well.
Old 02-20-2015, 07:12 AM   #26
Says the man from DFW, where it is not -11 F, like it is up here this morning.
Old 02-20-2015, 09:10 AM   #27
Kar98
Pretty scary shit, temperatures are expected to plunge into the double digits this weekend, and I might have to break out my winter flip flops!
Old 02-21-2015, 10:30 AM   #28
bairjo
Well as I stated, I am in the process of installing these. I got one side done and functional. So I took you up on your claim that directing the heater vents etc will work just as well as heated mirrors. So I packed both mirrors with some snow and ran a test. Not even close dude...The one with the heated mirror was dropping the snow off as it melted....the other side was getting worse as it is snowing here rather heavy and the falling snow was sticking to it.
After the snow was half gone from the heated mirror I shut it down as my neighbors may start to get a little concerned about me watching me video taping my mirrors in 14 degree weather.
Old 02-21-2015, 02:00 PM   #29
Kar98
Awesome! Congrats!
Old 02-21-2015, 05:26 PM   #30
jayeh
Drives: '08 Yaris LB
That doesn't even keep the front windows clear of fog in this kind of weather.
jayeh is offline   Reply With Quote
Old 08-26-2015, 12:53 PM   #31
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
video of heated mirror install
Hey, I would be interested in that video, please.
Thanks!
33.7 mpg in PA
bad is offline   Reply With Quote
Old 08-26-2015, 08:37 PM   #32
bairjo
Thanks!
Here ya go...it's a little hard to follow at times....just hit pause when you are at one of the spots in the video. Good luck with your install.
https://www.youtube.com/watch?v=5pkbGxqhYZI
Heated Side View Mirrors goku87 DIY / Maintenance / Service 27 01-26-2016 06:23 AM
Unlinking heated side mirrors / rear defrost Alezius DIY / Maintenance / Service 9 11-03-2010 02:29 PM
heated mirrors on 09 model? DOMAV General Yaris / Vitz Discussion 34 10-27-2009 05:13 AM
Replacing manual mirrors with powered plz help MikeB DIY / Maintenance / Service 0 05-27-2009 10:55 PM
Will '09 Heated mirrors fit on an '08? goku87 DIY / Maintenance / Service 1 11-17-2008 06:39 PM
