Old 09-18-2015, 08:48 PM   #1
rokmeamadeus
Drives: 2008 Yaris (Base) LB
Re-key question
Hi folks,
My Yaris seems to be having a rough few weeks. It was stolen earlier this week, only to be found three days later thanks to the Philly police. Apparently my key came off the keyring and (I'm assuming) fell somewhere on the sidewalk (I'm assuming) relatively near the car (everything else was intact on the keyring).
Yeah, I know.
Long story short, I have it in the shop for repairs but insurance won't cover lock replacement. My adjuster suggested I look into rekeying, and that sounds like a brilliant idea. I looked up on the internet and it seems to me like this could get expensive, but I'm unsure. Does anyone have any suggestions or ideas on the best way to proceed here? I'm still missing one key (I have two spares). Should I replace the locks (and ignition?), or should I rekey the car? Any guesstimates of how much this'll run me? It's an '08 Liftback.
Thanks!
rokmeamadeus is offline   Reply With Quote
Old 09-18-2015, 10:55 PM   #2
Rekeying would be quite expensive as you are looking at new lock assemblies all around as well as a new ignition switch. If you really want to do so it may make more sense to find a junkyard with a complete one that you can harvest the locks and keys from.
Old 09-19-2015, 12:49 AM   #3
rokmeamadeus
Ball-park numbers, am I looking at a few hundred, or >$1000?
Old 09-19-2015, 06:54 AM   #4
For new parts from the dealer, about $1000 + labor for non-power locks and $1500 + labor for power locks.
Old 09-19-2015, 07:02 PM   #5
Mongoose7
Drives: 2007 Yaris HB
Why do you want/need to re-key? Only because you lost one key? If that is the reason....maybe take it to a locksmith and have one pin changed in each lock cyclinder.
Mongoose7 is offline   Reply With Quote
Old 09-20-2015, 05:19 PM   #6
rokmeamadeus
Sorry, I thought that's what rekeying was. What I meant was that I'd like for the old keys (two spares plus the one I'm missing) to not work on either door, hatch or the ignition.
I imagine getting a locksmith to do this would be the cheapest option, although I don't know enough about locks/locksmithing to know exactly how it will/can be done. I'm planning on calling a locksmith tomorrow, but I was hoping to get an estimate of how much this might run me.
Old 09-20-2015, 06:25 PM   #7
I'm not sure if the cylinders are removable for rekeying by a locksmith, so I was talking about the cost to replace the locks and ignition switch.
Old 09-21-2015, 11:27 PM   #8
shepd
Drives: 2007 Yaris 5 door RS
Considering that, physically, most cars brands only have a few dozen actual keys for each type of lock they make, I wouldn't bother unless my plate was written on the key. It will open hundreds of thousands of vehicles and start them right now as it is. Some repo guys have entire master key sets so they can cleanly open the cars.
The key is, frankly, only there to keep honest people honest. It takes a thief about 10 seconds, probably less, to steal a car without any key at all... Smash the window, unlock the door, hop in, use crowbar to break the steering lock (Didn't bring it? There's always the tire tools in the trunk, or just look for cars sporting the club... convenient...), and crack the ignition with a flathead screwdriver. If you're worried about theft, you need a Yaris with an engine immobilizer instead.
If you have a vehicle with the engine immobilizer, I wouldn't bother with a re-key. Just get new keys at Toyota, and (I assume this is possible?) have them delete the lost key from the immobilizer.
shepd is offline   Reply With Quote
Old 02-24-2018, 10:18 PM   #9
jra
Drives: 2015 yaris L
Keep your insurance paid up and let them worry about the lost key.
jra is offline   Reply With Quote
Old 02-25-2018, 02:21 PM   #10
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by shepd View Post
It takes a thief about 10 seconds, probably less, to steal a car without any key at all...you need a Yaris with an engine immobilizer instead.
this is mostly the correct answer. you would just go get your code changed on all the keys. if non-immobilizer, it would be cheaper to disable the vehicle via fuel, ignition, etc. than to replace keys/locks or even re-key pins. or installing a super fancy alarm system would be cheaper.
Question about adding another key and fob rcvmini DIY / Maintenance / Service 19 10-14-2018 09:17 PM
2008 Toyota Yaris Immobilizer/Transponder Key ItsanEE DIY / Maintenance / Service 0 07-11-2015 03:48 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
key only ....and not remote question toyman In Car Entertainment + Electronics (audio / video / alarm) 1 05-23-2011 08:10 AM
Reemplazo Swichera yukardo Central and South America 3 04-03-2011 12:11 AM
