conundrum562
Drives: Toyota Yaris 2007 Type S Join Date: Jun 2010
So before I added the light weight crank pulley I was idling high like at 2000RPM+ now that I've installed the pulley it dropped it back down to normal.
As far as performance goes, it seems to lighten up the throttle. When I step on it lightly it speeds up normally but quicker, I have the S/C boost set on medium so it doesn't kick in until I step on it a little harder at around 4000rpm. The only thing is it doesn't seem to pull as hard as before when I had the old stock pulley... I dunno anyone else notice any differences or better performance let me know?
--------------------------------------------------------------- BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
It's not an under drive pulley is it? That would lower the rotational speed of the supercharger.
MICRO IMAGE - Light Weight Crank Pulley
MI didn't commission an under drive pulley.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I'm surprised a lightweight pulley can lower your iddle speed. I've never heared of that before.
You're right, the car it should accelerate the same way as a before, only it'll reach that high RPM quicker. That's the main performance benefit. Which gear/rev range does it not pull as hard? Does it pull less? Keep in mind, this type of pulley will not create HP.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#5 | |
conundrum562
| Micro Image JDM replica tails installed.. | Kiteless | Cosmetic Modifications (Exterior/Interior) | 26 | 08-02-2014 01:49 PM |
| NST Lite Crank Pulley | camelll | Items for Sale by private party | 5 | 03-15-2011 08:57 AM |
| 6lb 6oz ultra light weight battery | heavystarch | Performance Modifications | 28 | 11-19-2008 06:02 PM |
| NEW GROUP BUY: Yaris NST Crank Pulley (NonStopTuning) | NonStopTuning | NonStopTuning | 224 | 05-17-2007 07:40 AM |
| unorthodox or Perrin Light Pulley | abdiel hiram | Performance Modifications | 2 | 02-27-2007 04:45 PM |
