Old 09-24-2015, 08:11 AM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Manual transmission fluid replacement
Just wondering, how often should I change my manual transmission oil?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 09-24-2015, 04:10 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
I change mine at 50,000 kilometer intervals and use a full synthetic 75W90.
Shifts like a dream!
Old 09-24-2015, 04:33 PM   #3
Kitt
Kitt's Avatar
will do so, last time I changed it with the clutch/plate/bearing replacement
Old 09-29-2015, 01:42 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I typically will make sure that when I change mine (usually once a year) I perform a flush as well. Yes for most people my interval is way overkill, but I would much rather change it once a year than risk anything with how the car is driven at 7k rpm for long durations at high speeds. So back to the flush it does help with moving any broken down portions of the current fluid.
Sent from my SCH-I545 using Tapatalk
Old 09-29-2015, 09:05 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
With what do you flush?
I'd personally only use the same oil as I plan to re-fill with.
Old 09-29-2015, 09:58 AM   #6
fnkngrv
fnkngrv's Avatar
I use AMSOIL Transmission and Engine Flush
Old 09-29-2015, 10:11 AM   #7
Kitt
Kitt's Avatar
so, is it safe to do transmission flush that often?
Old 09-29-2015, 10:56 AM   #8
fnkngrv
fnkngrv's Avatar
I have had no issues with it but do not recommend for normal driving
Old 09-29-2015, 03:56 PM   #9
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Seems like Toyota OEM products would be your safest bet in this case, since it is supposed to be formulated with exact Toyota mechanical specifications in mind.
Kalispel is offline   Reply With Quote
Old 09-29-2015, 04:00 PM   #10
fnkngrv
fnkngrv's Avatar
The problem with the OEM fluid is that you run into the issues with shifting into reverse. The c50 is known for wear issues especially with the syncros as it is so the better the protection the safer you will be. Also for example AMSOIL, RP, Redline, etc meet or exceed API standards so they are perfectly fine to use.
Old 10-05-2015, 11:19 PM   #11
SirDigby
Drives: 2007 yaris 3 door
most of the time dealerships buy this oil in bulk from the near by oil/gas company. this is for the m/t that has 75-90 gl-4. it's kinda generic, but ok.
Manual Transmission Vent tmontague DIY / Maintenance / Service 3 09-08-2022 10:09 PM
looking for a new SE manual transmission dirkpitt73 Willing to Buy by private party 25 06-02-2014 03:25 PM
T-IV Auto Transmission Fluid on Sale Now Z2TT Australia 0 03-08-2013 01:55 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
