Old 10-03-2015, 11:36 PM   #1
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Stock cat delete cel?
Does anyone know if those 02 sensor spacers work to eliminate a cel if I delete the cat?
Caramanos2000 is offline   Reply With Quote
Old 10-04-2015, 08:51 PM   #2
SirDigby
Drives: 2007 yaris 3 door
a secondary o2 simulator sends a signal to the ecu about once every second at the correct voltage for a clean catalyst. a spacer just moves the o2 sensor away from the path. I don't know why you'd do this. if you remove catalyst an incorrect signal will be sent to the ecu tripping a cel. you should not remove your catalyst unless you are using car for racing only. you will only gain about 1-2 hp, but can incur a $10,000 epa fine if it is discovered it has been removed. FEDERAL LAW (idk about PR)
Old 10-05-2015, 01:26 PM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Agreed! If you do remove the cat, the only way to effectively get rid of a CEL, asside from using an aftermarket ECU, is to use a kit such as this:
http://www.magnumtuning.com/en/detai...r/toyota/yaris
A spacer could work, but there's really no guarantee.
more performace/MPG with cat delete? Shinare Performance Modifications 3 06-22-2013 09:20 PM
Secondary Cat Delete? ApolloJA Performance Modifications 4 04-28-2013 12:42 PM
Cat lovers, Cat haters, this is a MUST READ *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 10-14-2012 07:20 AM
FS/ 2007-2009 YARIS 3 DOOR STOCK PARTS ROCKLAND TOYOTA Items for Sale by private party 5 06-26-2012 08:50 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 05:19 PM
