Old 10-06-2015, 04:28 AM   #1
maverickhere
Drives: yaris sedan 2007
Question need help in swaping my yaris engine
hi all
i have yaris sedan 2007 with 1.3 vvti 1nz-fe engine... i made many searches to swap my engine ... the easy one is 1.8 2ZR-FE it is already in yaris RS.
there is other engine better 2ZR-FAE in corolla with better horse power and fuel consumption don't know it can fit or no..
my other opinion is 2zz-GE engine gives 180 to 190 hp .. but what i have to change in body or cut .. or it fits without cutting..
i prefer 1- 2ZZ-GE 180 hp
2- 2ZR-FAE 142 hp
3- 2ZR-FE 130 hp
the easy and availabe is 2ZR-FE .. with complete wire and ecu don't know should i buy with it transmission gearbox both have 5 manual .. also should i have to change the fuel pump and radiatior or no ?
lat question is 2 ZR-FE wiring should fit speed and rpm ... and should i change the whole exhaust system
maverickhere is offline   Reply With Quote
Old 10-07-2015, 05:35 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
There are a few threads about swapping the 2ZR-FE already on the forums. It's a bolt-in solution if you get the whole motor from a Scion xD. 2ZZ = lots of fabrication and wiring. 2ZR-FAE = unknown fabrication, unknown wiring.
Old 10-25-2015, 01:50 PM   #3
Rigaud
Drives: 2009 Yaris
2zz-GE has been done with the 6-speed. Mechanical, somecutting mostly to fit the transmission.
Issue is the wiring and you better be good at it or know someone. I found some 2ZZ with 6-speed and ECU for $2000 - $2500
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Engine Cooling System LED in Yaris lijet DIY / Maintenance / Service 7 09-09-2013 10:40 AM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
