Old 11-04-2015, 10:44 AM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
all-auto main power window control switch feature
I saw this feature in a Land Cruiser Prado, so I was wondering if this can be added to the Yaris, just by swapping the main switch or is it something that the body ECU controls?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 11-04-2015, 08:39 PM   #2
It could theoretically be done on the Yaris, as all of the brains of the window switching are in the master switch assembly.
Old 11-04-2015, 09:21 PM   #3
Kitt
Kitt's Avatar
so, what cuts the current to the PW motor when you press the button all the way down/up is a fuse on the switch itself?
Old 11-04-2015, 09:36 PM   #4
There is a single fuse that feeds all of the window motors. The window switch contains the current sense circuit for stopping the window.
Old 11-04-2015, 09:39 PM   #5
Kitt
Kitt's Avatar
got it, so as you said, it should work.
Old 11-04-2015, 09:52 PM   #6
In theory. A switch from another vehicle will likely not have the correct pinout, but if you can find the wiring diagrams for both you should be able to make it work.
Old 11-04-2015, 10:48 PM   #7
Kitt
Kitt's Avatar
iŽll keep on searching :)
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
