Old 04-13-2012, 01:20 PM   #19
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
With the 4 channel you can add the 6x9s later on if you miss them.
The fuses look at your amp fuse ratings.
Old 04-13-2012, 06:33 PM   #20
09sedan
Drives: 2009 yaris sedan
sounds good, i made a list and printed it off, time to start saving up for it :D,
now how in the hell am i gonna mount those damn tweeters .
also i have like 30 feet of 12 gauge speaker wire
looks like that^^.. is that good enough ? or do i need shielded wiring?
09sedan is offline   Reply With Quote
Old 06-04-2012, 05:59 PM   #21
09sedan
ordered the head unit! , Pioneer DEH -P7400HD!!
http://www.pioneerelectronics.ca/POC...rs/DEH-P7400HD
5 band eq and rear USB input( no more shitty ipods and their crappy headphone preamp!) also comes with 3 4V rca outs, subwoofers, rear and front. :D
Old 06-04-2012, 08:01 PM   #22
_S7V7N_
_S7V7N_'s Avatar
Few pics i got a few more
Old 06-04-2012, 10:00 PM   #23
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I had a local audio shop make me some 6x9 mounting brackets out of MDF. Cost me $10 and took them about 5 minutes. I used a dremel to widen the opening on the rear deck.
I have Infinity Kappas in the back of mine and no amp. They are loud enough just running off my Eclipse CD3200 so that I can't even stand to listen to them maxed out.
Old 06-04-2012, 10:09 PM   #24
_S7V7N_
_S7V7N_'s Avatar
My subs would shred the hell out of them 6x9's. Thats why i just left them as breathers. To let some of the air out the trunk.
Old 06-04-2012, 11:58 PM   #25
47_MasoN_47
Don't need subs with Kappas :P
Old 06-14-2012, 11:56 AM   #26
09sedan
Got my deck!, 4v rca outs, front/rear and sub , it has a 5 band eq and usb input, i now have all of my music on a high speed 32gig usb stick :D, a ton of color options and it cost me 180$
In the attachements one pic is of the deck installed, the other pic is the plastic cover on the door that covers the wire for the side mirror its kind of bad lighting but its inbetween the door frame and the window , i am thinking to mount the tweeter there for my component system(passive crossover), for now the components will be powered by the head unit, until i save up some money for a new battery and 4 channel, thoughts/opinions on that location?
Old 06-14-2012, 03:00 PM   #27
_S7V7N_
_S7V7N_'s Avatar
Old 06-15-2012, 09:05 AM   #28
09sedan
hey seven, how did you secure the tweeters to that plastic cover? ( my side mirrors are power, so i can mount that tweeter in the middle) , did you use hot glue gun on the inside of the plastic cover or screws or???
Old 08-27-2012, 09:41 AM   #29
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
So let me get this right, the 6X9's in the back need a special mounting bracket available on ebay or can use a template for 1/2" MDF? WTF kind of engineering idea was that?? :D Does anyone have the link for a bracket template? These rear speakers have to go... also, is there a link for the removal/installation for the interior trim etc ?? Thanks.
caper26 is offline   Reply With Quote
Old 08-27-2012, 05:24 PM   #30
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Just a site where you can buy them...
http://car-speaker-adapters.com/items.php?id=SAK008
D.
CLA 250, 4MATIC
Old 08-29-2012, 02:58 AM   #31
sqcomp
Roadrunner Jr.
sqcomp's Avatar
@ 09 -
You mean tweeter locations like this:
― Thomas Paine
Old 08-29-2012, 03:03 AM   #32
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That tweeter location can work well for width and stage height. What you're going to need to do is to adjust the left side amplitude to get the image into the center of the dash.
Your frequency and slope on the crossover will have some effect of the height.
― Thomas Paine
Old 08-29-2012, 08:21 AM   #33
_S7V7N_
_S7V7N_'s Avatar
Superglue and Duct Tape mannn !!!
Sq's are done professionally. I'd go for that flush look.
All i used is the mounting hardware that came with the components. Screws and nuts.
Old 08-29-2012, 11:02 AM   #34
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Done professionally...thanks!
Still, those were quite a lot of sanding and filling. Still, it was worth the time easily. The finish to the pods was time consuming.
― Thomas Paine
Old 11-20-2015, 12:10 PM   #35
ehud42
Drives: 2009 Yaris Sedan 5spd
Gah - these (6x9 rear speaker adapters) are like $50 by the time exchange, shipping, etc to get them to me in Canada. Man I wish someone would scan them and make an SVG file or printable template like was done for the circular hatchback adapters.
ehud42 is offline   Reply With Quote
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
