#73 | |
Mr. 155 and climbing
AEM EMSv2 with a custom built Dezod Motorsports harness. Sent from my XT1575 using Tapatalk
#74 |
That is a full standalone unit I'm assuming?
Looking forward to it starting up, should be some impressive power coming out of it
#75 | |
#76 |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
The whole setup is looking good, real frightening. Whats the weakest link in your Yaris after the new upgrades? Can't wait to see what you guys do with the downpipe/wastegate routing.
#77 |
Since I have the TRD dogbone and the torque damper the CV shafts should be fine. I still have a stock trans and even tho I now have that 6 puck ACT stage III clutch that could be an issue. An engineer from ACT pretty much said flat out that over 300tq and I will need a truly custom clutch assembly because he doesn't think it will hold up over the long haul at the duration I will be running with high rpm shifts. Guess only time will tell. Garm's axles as well as a few of the folks I have talked with from PTR held up fine with mid 300s. Chew I believe is still running stock axles on his 500+whp build.
#78 |
Well that's what you get for being one of the Yaris platform pioneers lol. Who's going to tune your Yaris after you're completely done?
#79 | |
#80 |
Are you going to record the dyno runs as well?
#81 |
Yes we do plan on doing so if all goes well.
#82 | |
![]() ![]() ![]() Sent from my XT1575 using Tapatalk
#83 |
We were going to custom fab up the battery kit, but in the efforts to cut time I instead picked up this kit from Taylor Cable. The good thing about this is that since it is 8.1 certified with NHRA the LSRs will accept it as well.
#84 |
That's a creative way of routing the dump tube in that small amount of space, she's going to make all kinds of scary noises.
Thank you for the pictures,is the fuel line/wiring loom/coolant lines that close to the dump tube or is it just the pictures? EDIT: Are you going to use a stock sized battery with that relocation? |
#85 | |
As for the battery no its not a stock size battery. it's actually a different battery which is smaller however still somewhat heavy due to the fact that it will provide me the additional amp hours needed to drive all of my extra electronics compared to what a racing battery would do. I got a great deal so pulled the trigger a few months ago: http://www.amazon.com/Kinetik-HC800-.../dp/B000LUDEOI We plan to mod the Taylor box to drop the size and conserve space in the trunk. Sent from my XT1575 using Tapatalk
#86 |
New Intake Manifold has been 100% completed as well as the throttle body being plumbed. Pretty pumped about this. Also a sneak peak of the new color scheme. The "satin black" appears to be much more of a gunmetal pearl, but it is starting to grow on me. The purple is in honor of the other half as it is her favorite color. Who knows if she will like it tho since she has grown to really dislike the car....haha.
#87 |
Is your fuel in line on the opposite side as stock or did you add a fuel return line?
#88 | |
we ran a new braided line for the fuel inbound and used the stock line for the return. that is the standard setup for folks that upgrade the system on these cars.
#89 |
So close to firing the sleeping dragon we can taste it.
Exhaust piping arrived to day: ![]() Quick and dirty of the remaining items: - valve cover blast and coat - coil pack vanity cover - install new valve cover stainless bolts - finish battery reloc - finish wiring for hot side AIT sensor - finish exhaust - install shift light ![]() ![]() ![]() Sent from my XT1575 using Tapatalk
#90 |
Can't wait to hear it fire up, looking forward to the videos of that happening
what is that second smaller looking airfilter located near you intake filter? Second Q is why do you run a return fuel line vs how it's set up stock with no return line? I'm assuming it has something to do w/ the extra fuel pressure you need to run with the larger injectors.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| Whats needed to turbo charge the yaris? | Arkhangel | Forced Induction Forum | 44 | 03-02-2009 10:08 PM |
