![]() Drives: 2007 Yaris Join Date: Dec 2015
Yaris 2007 4 Door Bulb for Heat Venter Switch
The panels are out and the cover is off but where the heck is the bulb, the center AC light is ok it's just the outside light that's out.
Lots of control wires behind this, can anyone tell me how to get at this bulb without me breaking all kinds of plastic? |
Once you disconnect the white plastic piece for the cable, you will see a recessed area in the center of the back of the knob. The bulb is mounted into a plastic carrier there. Just use a flat head screwdriver to release it.
#3 | |
Do I leave the big white plastic block where it is? or do I try to get this out? |
The white block does have to be removed. There are a couple of slots in the black plastic that tabs of the white part snap into. Once you release them the whole cable holder is free.
So you leave all the cables attached to the white block and just inch out the white plastic block and the bulb is in there?
I would assume there are plastic tabs that need to be lifted to pull out the white block? |
I see the green bulb but it wont come out now it seems loose but will not come out?
Once you rotate it counterclockwise to release it you will either need to tilt the control panel to get it to fall out, or reach in with a small needle nose pliers to pull it out.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
