#37 |
another thing to keep in mind is there is this stupid carbon filter on the top half of the airbox cover. it is plastic riveted in. if you remove this extra filter it's good for a few more CFM....if you plan to keep your stock box
#38 |
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
I have one of those drop in k&n's.hasnt helped the mileage or power 1 bit.going on 8000 miles.
#39 |
For what it's worth, I took the K&N drop-in out after first reading about MAF gunk up in this thread. After reading a bit more and learning it comes down to the amount of oil on it after cleaning, I put it back in. Noticed a smoother idle. Can't speak for power and MPG seems the same, but definitely noticed a smoother idle.
#40 |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
K&N does not help much..i feel like it just saves money by washong, drying and putting them back on..
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 12:03 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
