Old 08-03-2015, 03:25 PM   #181
meszar
Drives: Toyota Yaris 2014
Brown - 0
Grey (right of brown) - 5 - 5,5
meszar is offline   Reply With Quote
Old 08-04-2015, 06:09 PM   #182
Originally Posted by meszar View Post
Brown - 0
Interesting. I have not had the opportunity to measure the voltage on the CCS wire of a third generation Yaris, so the 5V, rather than 12V might be OK.
Try jumping the brown to the grey with the Ignition ON, but engine off (you can use a bent paper clip or small piece of wire). If you touch those two terminal together briefly you should be able to toggle the cruise control symbol on and off on the cluster, if it works.
Old 08-09-2015, 05:33 PM   #183
As far as I am aware, the 1.0L does not have the ECM programming for cruise control.
Old 08-09-2015, 07:04 PM   #184
Originally Posted by ghidz View Post
Oh hell. What happen if i go to the dealer? can they reprogram the ecm or is not possible?
No. You would need an aftermarket cruise control system, which can be quite costly.
Old 09-14-2015, 12:00 PM   #185
texascolt45
Drives: 2015 yaris
anyone try this on a 2015 1.5 liter L model with an auto trans?i'm curious to know if it will activate the cruise.
texascolt45 is offline   Reply With Quote
Old 09-14-2015, 04:34 PM   #186
Yes. I have sold quite a few kits to people with 2015s.
Old 09-15-2015, 04:22 PM   #187
850spdr
Drives: 2013 Yaris 4d
ECM pinouts question
Hi-
I have a 2013 Yaris which has a no start will crank problem. My ECM connector configuration and pinouts are different from those on the TIS documentation.
Is there some way I can get valid connector drawings and signal lists? My ECM is a 89661-52R40.
thanks
850spdr is offline   Reply With Quote
Old 09-15-2015, 05:02 PM   #188
Originally Posted by 850spdr View Post
Hi-
thanks
Please post a separate thread instead of hijacking an unrelated one.
Old 12-19-2015, 10:52 AM   #189
doller
Drives: '15 fire red yaris 1,33 vvt t2
Hi
which Toyota part number cc stalk do you yaris sorcerers recommend for my 2015 yaris 1,33 vv-t ?
thumbs up from denmark
wow first post
doller is offline   Reply With Quote
Old 01-07-2016, 04:44 AM   #190
nikatsgr
Drives: yaris diesel 2012
sorry for my poor english.first time in forum.In my Toyota Yaris D4D 2012/07 model STYLE TYPE- NLP130L-CHFSXW, everything is in place,and the clutch switch s in place in the pin 1-2 ihave 5 volts in grey wire and 0 in brown i have put a used oem cc switch and did not work!!i have read that european yaris not support cruise control.is it definately???any solution???thanks any way!!!!!
nikatsgr is offline   Reply With Quote
Old 01-07-2016, 12:24 PM   #191
marspike
marspike's Avatar
Drives: Yaris 2014, Y. HSD 2013
I have same engine, but mine was product in end 2013 (Business). And mine was delivered with factory CCS whose worked. Two thing, once your CCS was not plug on pin 40 to the ECM. Or second possibility your ECM was not progammed for a cruise control switch.
ECM is a metal box located under the hood in difficult access behind secondary fuse box in right passager side.
marspike is offline   Reply With Quote
Old 01-08-2016, 05:32 AM   #192
nikatsgr
ok i will search for pin 40 and if is not pluged anything what shall i plug on it???and second
can i reprogramm my ecm (not me offcourse)or something is missing from ecm?
Old 01-15-2016, 07:29 PM   #193
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Red face
Big thanks to CTSCOTT for letting us know this was possible. I have just fitted cruise control to my 2012 Austrailan 1.3L yaris. I only bought the Yaris recently as a second car, and was nearly put off the purchasr because of the lack of cruise control. I found a switch on eBay for AU$17 delivered for whatwas a $650 option in 2012.
For the 2012 model with steering wheel audio controls you don't need to disconnect the battery or airbag, but it's a good idea to remove the horn fuse from the fuse box next to the battery when you go to push the central airbag and horn button back on to the wheel. If you don't the horn will sound when you push the airbag unit back on to the montings.
Old 02-03-2016, 05:04 PM   #194
amit87
Drives: MY63 Toyota Yaris 1.33SRManual
OK I finally done mine! I am from the UK, I ordered the cover part from toyota (part# 45186-0d030-C0 (C0 = black) and cost me £5.60 inc VAT.
I ordered a non OEM stalk off ebay for cheap but hopefully will last and looks/works/feels OEM.
So disconnected the battery, removed airbag, put it all in, put all back together.. DONE! How long did it take... 10min? 15min? 20min? 30min?... nope! 1 whole hour!!!!! thats start to finish. 45min of that was battling the airbag clips!
My car is a 2013 (MY63) Yaris SR 1.33 Manual 5door. It already had the secondary clutch switch etc so literally was plug and play. When connected battery, only thing that rest was the clock, the touch&go even resumed my song so dont worry about having to set everything again, just the clock!
The first clip of the airbag was easy, small screw driver and push and it pops out. The other two... well lets just say I couldnt pull the clips down, they are tougher than I thought! How I got it out eventually was by pushing down in the plastic clips of the airbag which some how released both but this is easier said then done! I was violent so dont be scared, nothing will break as long as you know what you're jabbing. To help me get more access I also removed the steering wheel buttons trim by un doing two screws (1 is oposite the other and are obvious). It wouldnt come off as the airbag was still clipped in but I could pull it off enough to get more access. Thats my tip!
amit87 is offline   Reply With Quote
Old 03-04-2016, 12:18 PM   #195
boooggy
Drives: 2014 Yaris lb 1.33L
Hello
I have a yaris European model, engine 1nr-fe.
CTScott, do u still have the kit for cruise control?
Thx
boooggy is offline   Reply With Quote
Old 03-09-2016, 03:41 PM   #196
-roninn
Drives: Yaris
Control buttons on the steering wheel.
Hello everyone.
I have a Toyota Yaris 2015, 5 door, the European version, with control buttons on the steering wheel.
Does anyone know for what are the wires in the connector (D103 black)
pin 10 - red ?
pin 11 - pink ?
pin 12 - blue ?
I suspect that these pins are of a radio control.
Can somebody confirm this?
roninn
-roninn is offline   Reply With Quote
Old 04-12-2016, 07:58 AM   #197
panayiotis
Drives: yaris 2016
hello.i have a 2016 1.33-VVTi Active 1NR-FE automatic eur model right hand drive.does anyone know if i only need the stalk?
panayiotis is offline   Reply With Quote
Old 04-12-2016, 06:40 PM   #198
Correct - You just need the stalk and the replacement steering wheel side trim piece.
Tags
cruise control. 2012
