Old 12-05-2009, 11:44 PM   #1
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Serpentine belt replacement.
Hey guys I've got 70k miles now and my belts starting to make some noise.
It looks like it's getting a little dried out.
Has anyone replaced theres on their own?
I don't have a lift and it doesn't look very easy to get to from the top.
Old 12-06-2009, 12:31 AM   #2
Check out the thread below. It's actually not bad to do. You just loosen the two alternator bolts (from above), pivot the alternator towards the engine, pull the belt off, put the new on on, and re-tension.
http://www.yarisworld.com/forums/showthread.php?t=20766
Old 12-08-2009, 12:53 AM   #3
Phaeton
Phaeton's Avatar
sweeet thanks.
Old 01-10-2016, 12:24 AM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Just like to say that i just replaced my belt today ($17) for the first time because it started making noise on startup.... Car has over 137k miles on it. I love how reliable this car is. 8 years on a belt, 7 years on the stock battery, 120k on the brakes, 130k until the first headlight went out. And the repairs are easy. Wish all cars were this good.
Old 01-10-2016, 08:58 AM   #5
bronsin
bronsin's Avatar
When you tension the belt beware of damaging sensors or components on the engine block with that prybar. I forget exactly what its called but many report to be careful what you pry on.
Shorter Serpentine Belt? The Architect Performance Modifications 6 04-20-2021 11:42 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 06:50 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 01:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 10:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-13-2009 12:05 AM
