![]() Drives: 2007 Join Date: Jan 2016
Air Conditioner emits vapor and water
Hi! I recently purchased a 2008 Yaris 4-door sedan with just over 100,000 miles. When it got hot over Christmas (yes, Christmas) there was a vapor or smoke coming from the vents. I continued to run the a/c and water was coming out as well. There wasn't any smell or oiliness that I could see. Today I raised the hood and there is a film of like oil over everything and I'm pretty sure it isn't coming from the motor. Any advice as what it could be?
I did do some research and see where if the drainage thingee is clogged there is a sloshing sound when you turn left and the passenger-side floorboard is wet. I don't have those symptoms. TIA! |
#2 | |
The oil cap is on. The oil level is slightly over full - it came that way. Does this mean the compressor is bad and needs to be replaced? I didn't run the ac for very long but it was blowing cold. I'm afraid to turn it back on because of the water coming out of the vents and it has been cold here lately.
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Did it smell sweet at all when the smoke/steam was coming out? If you dare, you can taste the residue and if it's sweet: it's coolant. Your heater core may have a leak and it letting steam/coolant into the cab.
Cheers. |
Heater core leak would make sense, except it wouldn't cause the oily residue under the hood.
I've run the heater and haven't had any problems from it.
#8 | |
But I would make sure the drain for the air box is clear of debris. Just need to push a coat hanger or screwdriver up the tube from under the car. |
I'll bet Scott is right. Your evaporator core probably ruptured and sprayed a mist of oil and gas out the vents. The film on your engine is probably from it coming out the drain hole. Have a look at the a/c drain hole. The green oil should be evident there if so.
Ok, I'm gonna check this out. I just wish I knew more.
