![]() Drives: Yaris '06 1300cc Join Date: Dec 2006
Rear brake disks sliding bolt torque
Hello guys, I am searching for the correct torque that I need to apply when I will remove the sliding bolts from the rear brakes in my Yaris. The model is 2006 and the back axle has brake disks. It is rather challenging to find info for the removal of rear brake disks, because all the manuals that I've found so far, they have only drum brakes related info.
Thanks a lot! |
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
Your car came from the factory with rear disk brakes? That's pretty cool.
I would call the dealership and ask one of the technicians. |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I've noticed that the torque specs for front caliper bracket and pins for the Yaris are the same as the Corolla torque specs.
I would say go with the same specs as the Corolla rear disk breaks and you probably won't go wrong.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#4 | |
39 N-m (400 kgf-cm, 29 ft-lbf) for the slide pin torque.
Yes, it was from the factory
![]() Thank you very much CTScott you saved my day, I have been searching for this info a couple of days in manuals and I was about to go for corolla specs. |
I return back with one more question regarding torque. The place is rear brakes with disks and the bolts is the one in the photo. Any input is very welcome :-)
I finally found the info that I was looking for. Here are the torque for the rear disk brake in a 2SZ-FE:
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
