![]() Drives: 2007 Yaris Hatchback Join Date: Apr 2013
Megan front lower strut bar install ?
Got a Megan front lower stut bar for my 2007 yaris hatchback, everything I read seems to be a simple install so I purchased one. As recommended after using a breaker bar to loosen and used an air wrench to spin out the bolt. The bolt comes out about 3 1/2 inches and then just spins I tried reinstalling and loosening again and putting downward pressure to no avail. I cannot see the other end where this bolt goes up into the chassis. Anyone have any ideas? or done this?
Thanks After lifting up the carpet and confirming no nuts, used small sledgehammer hitting a vise grip, after lots of rust, bolt fell out. DONE, let you know if I feel any difference. Last edited by emgconsulting; 03-01-2016 at 12:58 PM. Reason: Solved |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-22-2011 07:32 PM |
| front sway bar install | birdman | DIY / Maintenance / Service | 5 | 10-04-2009 08:41 AM |
