#181 | |
2ZR swap. DO IT! Ask how!
The quicker way is to spend the same cash on a used gearbox from the year you need. Probably in the $400 range for a used one with low miles. |
#182 | |
-Edit- I looked at the EWD for the '06 Yaris and it has the same connection for the instrument cluster as the xD. Where that signal comes from in the ECU, I can't say for sure. I would assume that it comes from the ABS sensors on the xD hubs, so you may have to at least swap those over to restore your speedo functionality. I guess the only way to know for sure is to put it in and see what it does. -Edit edit- That of course would require swapping in the wire connections for the ABS sensors in the hubs. Hmm. You may be in a tough spot here, unless you use an aftermarket speedo. Last edited by CrankyOldMan; 02-21-2016 at 09:41 PM. |
#183 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Just use your yaris trans...the 2zr with bolt ons only makes about 150hp so its not going to break it
#184 |
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
#185 |
Data doesn't lie
Update: Ive put 2100 miles on my 2zr so far, no problems yet. Im going to send in a oil sample when I do the first oil change. I have another autocross in just over a week, and Ill probably wait 6 months before I go back to a racetrack. I want to be sure all is well before I run 20 minute sessions.
#186 | |
finding a xd in manual is difficult enough, let alone finding a manual ecm and harness. can some of these parts be taken off a corolla or matrix? such as the mounts/intake/exhaust/etc? edit: more importantly the electronics? Last edited by Frank the Tank; 02-27-2016 at 07:26 PM. |
#187 |
The wire harness is going to be tough, no doubt. I found quite a few on car-part.com, but most are in the $350 range. The MT ECM is pretty common on there, can be had for $50-75 USD. If you want to use the Corolla or Matrix electronics, you have to get the small ECU connector from the engine wire harness to reach all the way from in front of the passenger's seat to the fuse box/battery.
#188 |
Data doesn't lie
On post #1 I put a tip there for everyone so we aren't discussing the same questions over and over....
"Please read the entire guide" The 10+ corolla ECM has immobilizer but I dont know about the 09, and the corolla harness does not match in any way.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 02-27-2016 at 11:13 PM. |
#189 |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
Correct me if I'm wrong, but I thought the wiring harness on the XD was the same whether it was from a manual or auto trans car?
#190 |
Nope. The engine wire harness includes the A/T park/neutral position indicator or the M/T back-up light connector, depending on the trans. If you don't care about backup lights, then either will work for an M/T. I don't know that the A/T ECM will be happy about not getting info from the trans, especially for the key lock signal.
#191 |
Data doesn't lie
^Not only the P/N switch, but the other trans plug that controls the entire valvebody....and then there is the overdrive solenoid on top of the trans...
I used an auto trans corolla harness....and it was a nightmare. I had to cut the fusebox connectors off and solder on the connectors from my 1nz harness....AND relocate my Xd ECM. Dont try this without great wiring experience. |
#192 |
Data doesn't lie
Another win for the 2zrVios!
#193 |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Very nice. Looking at some of those times of the way more expensive cars, and seeing what you do, it really is awesome to see. When people ask why "waste our time" with our cars, this is exactly why.
#194 |
Puttin' a hurtin' on the Speed 3... Impressive!
#195 |
#196 |
Data doesn't lie
I did, but mostly because STF ran on a wet course...and it was completely dry for SMF.
I am doing well so far, but I know the car has so much more speed in it. Im far from being a National champ, but Im learning as I go.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 03-08-2016 at 12:47 AM. |
#197 | |
Get some race tires.
#198 |
^^I agree, compare your times to the STF guys. your goal is to beat them by a couple seconds. It is good that you are coming in 1st in SMF. All it takes is a decently prepped civic and you will know what humble feels like, lol.. Congrats on your 3rd win
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
