![]() ![]() Drives: Yaris HB Join Date: Dec 2014
Well... Here is one of the classic modifications. The sound changes a bit. The real difference is felt above the 4K revs.
I had no problems with the installation, it fits perfectly..
VELMAX member. Last edited by man83; 03-27-2016 at 12:20 AM. |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Very cool. Looks great!
Enjoy the new header. It's a great product that improves the torque curve quite a bit. I was impressed when I installed mine.
Now just fork out the cash for a Golden Eagle intake manifold and pair it with a short or cold air intake and you'll love your Yaris even more
#4 | |
Thank you.
I had seen the GE IM, and definitely this will be my next performance upgrade.
VELMAX member. |
#5 | |
![]() Drives: Y-sedan'07-1nzfe engine swap Join Date: Dec 2014
![]() Sent from my C6903 using Tapatalk |
O2 sensor. There is a bung on the DC header for it. It may not have been installed in the above image but you can see the bung for it in the comparison image of the oem header and the DC one
![]() Drives: Yaris Sedan YRS Join Date: Mar 2013
Where can I purchase DC header for my Yaris Sedan and I am from South East Asia?
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
its a 02 sensor...i had to put a hole in mine since mine was old vitz(jdm version) aftermarket header...
you should carefully remove from your old header and place them on to your new header Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#9 | |
Well, that is all said O2 sensor. The shape of the tube leaving not see the sensor. I'll take a picture so you can see how it looks.
VELMAX member. |
![]() Drives: '15 Yaris 3 door Join Date: May 2016
Nicely done! Does anyone know if these will fit a '15 three door?
Here is the pending picture. There you can see the sensor.
VELMAX member. |
![]() Drives: 08 Yaris hatch back Join Date: Nov 2016
other than the header is everything else stock exhaust??
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Yikes you removed the cowl to install it?
When I installed my WeaponR header I did not need to
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#14 |
![]() Drives: Yaris YR 2013 Join Date: Feb 2017
#15 | ||
Hello Jess, I also change the entire pipe, here is the thread: http://www.yarisworld.com/forums/showthread.php?t=57118
VELMAX member. |
#16 |
did you have any issues with heat on surrounding parts given the headers don't have a heat shield? I'm wondering if I need to wrap the headers or try and modify the heat shield to fit.
#17 |
do not wrap the headers, they are ceramic coated and are not meant to be wrapped.
I never had any issues with no heat shield when I ran the DC header and in most cars I've owned I cut the heat shield off when it rusts out and rattles. I removed the heat shield on my 2zr before I did the swap since it was close to rusting in a year or two. Most heat shields are to stop things like leaves which get trapped in the engine bay from landing on the header and starting a fire. You'll be fine without it, no worries
| 5spd 2008 Toyota Yaris trade for auto yaris | tengys | Cars for Sale by private party | 8 | 03-07-2016 05:04 PM |
| 2008 PeterPoop's Turbo Yaris 5 speed Base model. | PETERPOOP | Cars for Sale by private party | 32 | 07-18-2011 03:34 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
