Old 03-26-2016, 09:53 PM   #1
man83
Drives: Yaris HB
Talking ►►►DC Sports Headers - 1NZ Yaris 2008 HB
Well... Here is one of the classic modifications. The sound changes a bit. The real difference is felt above the 4K revs.
I had no problems with the installation, it fits perfectly..
VELMAX member.
man83 is offline   Reply With Quote
Old 03-26-2016, 10:05 PM   #2
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Very cool. Looks great!
brushforhire is offline   Reply With Quote
Old 03-27-2016, 12:25 AM   #3
tmontague
tmontague's Avatar
Enjoy the new header. It's a great product that improves the torque curve quite a bit. I was impressed when I installed mine.
Now just fork out the cash for a Golden Eagle intake manifold and pair it with a short or cold air intake and you'll love your Yaris even more
Old 03-28-2016, 06:27 PM   #4
man83
Drives: Yaris HB
Thank you.
Believe me that I am enjoying it. Now I have a CAI with AEM filter. I have also installed a Magnaflow exhaust too.
I had seen the GE IM, and definitely this will be my next performance upgrade.
VELMAX member.
Old 04-23-2016, 12:47 PM   #5
sang pengembara
sang pengembara's Avatar
Drives: Y-sedan'07-1nzfe engine swap
Originally Posted by man83 View Post
Thank you.
What is this sensor???.. I do not see installed at new header. Are you remove it?
Sent from my C6903 using Tapatalk
sang pengembara is offline   Reply With Quote
Old 04-23-2016, 01:55 PM   #6
tmontague
tmontague's Avatar
O2 sensor. There is a bung on the DC header for it. It may not have been installed in the above image but you can see the bung for it in the comparison image of the oem header and the DC one
Old 05-13-2016, 01:25 PM   #7
marion2
Drives: Yaris Sedan YRS
Where can I purchase DC header for my Yaris Sedan and I am from South East Asia?
marion2 is offline   Reply With Quote
Old 05-15-2016, 10:20 AM   #8
rabbito
rabbito's Avatar
its a 02 sensor...i had to put a hole in mine since mine was old vitz(jdm version) aftermarket header...
you should carefully remove from your old header and place them on to your new header
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 05-19-2016, 11:51 AM   #9
man83
Drives: Yaris HB
Well, that is all said O2 sensor. The shape of the tube leaving not see the sensor.
I'll take a picture so you can see how it looks.
VELMAX member.
Old 05-23-2016, 08:55 PM   #10
Anchors15
Drives: '15 Yaris 3 door
Nicely done! Does anyone know if these will fit a '15 three door?
Anchors15 is offline   Reply With Quote
Old 12-07-2016, 10:44 PM   #11
man83
Drives: Yaris HB
Here is the pending picture. There you can see the sensor.
VELMAX member.
Old 02-04-2017, 10:50 AM   #12
JessMess
Drives: 08 Yaris hatch back
other than the header is everything else stock exhaust??
JessMess is offline   Reply With Quote
Old 02-04-2017, 11:58 PM   #13
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Yikes you removed the cowl to install it?
When I installed my WeaponR header I did not need to
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-06-2017, 03:31 AM   #14
williew2
Drives: Yaris YR 2013
would improve access though...
Thanks for the photos, very useful as I'm looking at doing the same but with 4-2-1 header :)
williew2 is offline   Reply With Quote
Old 02-21-2017, 06:02 PM   #15
man83
Drives: Yaris HB
Hello Jess, I also change the entire pipe, here is the thread: http://www.yarisworld.com/forums/showthread.php?t=57118
Yes, it's more comfortable to work.
Share it when you do it
VELMAX member.
Old 02-22-2017, 01:09 AM   #16
williew2
did you have any issues with heat on surrounding parts given the headers don't have a heat shield? I'm wondering if I need to wrap the headers or try and modify the heat shield to fit.
Old 02-23-2017, 05:28 PM   #17
tmontague
tmontague's Avatar
do not wrap the headers, they are ceramic coated and are not meant to be wrapped.
I never had any issues with no heat shield when I ran the DC header and in most cars I've owned I cut the heat shield off when it rusts out and rattles. I removed the heat shield on my 2zr before I did the swap since it was close to rusting in a year or two.
Most heat shields are to stop things like leaves which get trapped in the engine bay from landing on the header and starting a fire. You'll be fine without it, no worries
5spd 2008 Toyota Yaris trade for auto yaris tengys Cars for Sale by private party 8 03-07-2016 05:04 PM
2008 PeterPoop's Turbo Yaris 5 speed Base model. PETERPOOP Cars for Sale by private party 32 07-18-2011 03:34 AM
