![]() ![]() Drives: 2007 Yaris hatchback Join Date: Feb 2016
Yaris serpentine belt!!!
Hello everyone I'm confused of what belt to buy I'm going to change the serpentine belt on my 07 Yaris hatchback but I don't know whether I need to buy the belt with AC or without AC? Can someone please help and I know I have to be very careful as I don't want to Damage the oil control valve because I replaced that 2 months ago ;)
#2 | |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
What's the reason you want to change that belt in the first place? They generally have a pretty long life time.
Sent from my LG-D801 using Tapatalk |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Serpentine Belt Noise
Some time I heared the noise when start from cold looks to me loud squeal noise.
After 10-20min drive it disappear. I tried soap on the belt and the noise increases. I then clean the belt with soft brush and pulleys with the same. The noise is v low now but I will double check this again and provide an update. I just share this it may benefit to someone who is in same situation so no soap or wax clean the belt with dry soft brush. |
Lubricating a pulley system with soap. Yeah, that'll never work.
If noise is less now, chances are you increased the tension on the belt after your cleaning efforts. That is assuming you had actually loosened or removed the belt. However, that belt, if it's original is old and a prime candidate for replacement. Sent from my iPhone using Tapatalk
Hi
I want to change it because the previous owner neglected the car I know it was change at least once because is not the factory belt but just so that I have more peace of mind :)
How often does the belt need to be changed say if I do it now with 150000 miles when would I have to do it again?
change the darn thing....it's not like you are rebuilding the transmission.....it's not going to break the bank and you can stop worrying about it.
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
^ +1
| yaris 1999 drive belt problem | xKYLE96 | General Yaris / Vitz Discussion | 3 | 12-02-2015 10:14 AM |
| drive belt problem for 1999 yaris | xKYLE96 | DIY / Maintenance / Service | 0 | 12-02-2015 08:24 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| 2008 Yaris S driving belt | socjo1976 | California | 9 | 03-16-2011 05:52 PM |
