![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Cabin noise..sucks..
having terrible cabin noise after 100km+ since i bought my car....i threw away the dunlop stock shit tires and put on pair of hankooks..it made the cabin noise much better but still having issues...anyone done any modification?
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() Drives: '15 Dodge Challenger Join Date: Aug 2011
A few people have done some deadening in their cars on the forum here
this is the one i read http://www.yarisworld.com/forums/showthread.php?t=27361 If you believe the sound is coming from the wheel wells the most, you could try pulling off the plastic liner in there and spraying a can of bedliner inside the wheel wells and put it all back together and see if that helps |
Live with it. Get used to it. We all do.
Rare is the Yaris owner who takes sound deadening measures. Sent from my iPhone using Tapatalk
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
I know I bought Knuconcepts sound deadening material. I then gutted the entire car. I put pieces/sheets anywhere the sheet metal would resonate when I rapped on it from the outside. It was alot of work, but it really helped.
I also added sound blocking material between the door trim panels and the door shell. It helped with alot of the noise also. I did have to come to the terms with the fact, that is is a econo car and noisy. Quiet costs lost of money and time. |
#5 | |
LOL i am weak af...
Boost up your sound system...
everybody driving yaris acting like a savage lol
Fred drives a Yaris?
fred in yaris.jpg |
So the op has a bunch of mods done on the yaris & wonders why its noisy.
| Colour Collection 05 Reg (UK) brake noise | JLx | DIY / Maintenance / Service | 0 | 07-14-2015 06:56 AM |
| metallic noise when accelerating | poida | DIY / Maintenance / Service | 3 | 03-29-2015 12:20 AM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 12:27 PM |
| Is there any product that can help reduce engine noise into the cabin? | swidd | DIY / Maintenance / Service | 18 | 03-30-2011 06:10 PM |
