Old 04-25-2016, 11:43 PM   #1
2slowjetta
Drives: 2013 yaris
2013 yaris hatch wont open
the fuse is good and locks open good by key and interrior i did notice i hear nothing now once i push the hatch button any way i can open it? ps... it has no key hole sorry for my english
2slowjetta is offline   Reply With Quote
Old 04-26-2016, 05:18 AM   #2
There should be a small plastic cover on the inside that you can remove and then flip the lever with your hand.
Old 04-26-2016, 08:38 AM   #3
2slowjetta
Drives: 2013 yaris
Any specific location?
Old 04-26-2016, 07:39 PM   #4
Lower center of the hatch. Directly in line with the latch. The MK2 Yaris have a cover about 10 cm x 5 cm that can be removed from the inside to release the latch. The MK3 should as well.
Old 04-30-2016, 07:40 AM   #5
2slowjetta
Drives: 2013 yaris
thanks for the quick info! but sadly mine does not have it
Old 04-30-2016, 08:20 AM   #6
Interesting. I see that now, looking at the service manual.
Unless you can yank the hatch trim off from inside, you may be stuck having to add and access hole on the inside.
Old 04-30-2016, 08:09 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
The hatch release on my '07 was manual, and there was a small removable door on the inside trim in case you ran into any trouble. The hatch on my '14 is electric I believe, and there is no such removable door. Could it be a fuse in this case?
Old 05-16-2016, 04:45 PM   #8
2slowjetta
Drives: 2013 yaris
I changed the fuse and it is still not working
Old 05-17-2016, 01:09 PM   #9
Dabuu
Radical Dreamer
Drives: spiritedly.
I doubt it's a fuse. Alot of systems share a fuse, so if it was, you would see something else that isn't functioning properly. Maybe the rear door relay, but, it's (rear latch) controlled by the main body ecu.
The unlatch signal is sent to the Main Body ECU. The MB ECU then outputs a signal to the rear door motor allowing it to unlatch.
Depending on your Yaris' first date of use, and current mileage, the 36 month 36,000 mile warranty would cover it. If not, a MB ECU is going to cost alot, but that's worst case. It could be a broken wire somewhere. So unless you buy the electrical wiring diagram from Toyota, this might have to be a dealer visit.
It's not that simple to fix a stuck door lock nowadays. :P
Dabuu is offline   Reply With Quote
2012+ Yaris rear hatch curvature for spoiler yarisugi Third Gen Yaris General Discussion 5 07-10-2015 02:59 AM
Toyota Yaris Ready to Rally in 2013 TagRallySport to Run Toyota Yaris in 2013 America Tagrallysport Photo-Video-Media Gallery 7 11-15-2012 04:40 PM
What will fit in a 5 door hatch Yaris? ruby9c New YARIS Purchase Forum 16 12-31-2010 12:46 PM
