#19 |
Sounds more like a creaking sound, and I noticed that it only does it when I'm pressing on the clutch slowly. HELP!
#20 |
Not quite a noob
Maybe it's time to feed the hamster in the wheel..
#21 |
#22 | |
#23 |
I've got this same problem and lubing that arm to the left of the pic did not stop the squeaking. It's been squeaking since winter.
![]() @Kaotic Lazagna: the boot in the middle goes into the opening. You'll notice that the end of the boot closest to the opening has a squared dip and this goes inside the opening. |
#24 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Bumping an old thread.
I was able to take care of the shift linkage squeak, but when I push in the clutch pedal (no matter what gear), it's squeaking. Can someone confirm that this is indeed the clutch fork? And I'm still not clear: Do I have to pull the clutch apart if it is?
Subcompact Culture: The Small car blog |
#25 |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
I had this problem about 2 years ago and was remedied by lubing the shift fork and other components near the proximity. Haven't heard a squeak since then. My shift has improve a bit.
Use redline MT 90 and nulon g70 gearbox treatment. I have yet to install my micro image short shifter. |
#26 |
shift fork
I have the same problem.,
So how do you get to lubing the shift fork ? and what parts do you need to remove to get to it. is it the area with the blue arrow in this picture? is there where we need to lube? |
#27 | |
#28 |
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
I "tried" lubing the clutch fork with the above method after I lubed everything external and it still squeaked. Not an easy thing to do since space is very limited. I tried using a long artist paintbrush attached to a safety wire in case I dropped it in and a lighted mirror and was still not able to really see what I was doing inside. I eventually shot some lithium grease inside (not a great idea I know) and it worked for a few months. The squeak is now back on occasion and I have decided to live with it or try the above method once again. If anyone has any ideas how to make this easier please chime in.
Thanks |
#29 | |
lol ah and try putting lube in all shift linkages removing the boot. etc.HERE'S THE OTHER COMPONENT TO LUBE.http://www.yarisworld.com/forums/sho...ghlight=squeak |
#30 |
thanks
Thanks fellas
, I just realized that I should have done it when I replaced the radiator a few months back...UURRRGGG! ![]() BTW great pictures ctscott |
#31 |
![]() Drives: Yaris Join Date: Mar 2014
Hey everyone! First off, thanks for all the shared advice. I've got the same problem on my Yaris. Just tried all the tricks I could find on here. Definitely got better. I greased teh cilinder inside the car directly activated by the pedal, then the cilinder pushing against what I guess is called the clutch fork. I sprayed under the rubber thing. There used to be a squeek like a squeeking barn door, almost a rattle. That seems to be gone now. I'm left with a high pitch squeek coming from somewhere around the cilinder besides the engine. Can't get that to stop.
Could it be the clutch fork pivot inside the transmission? I mean the thing behind the rubber on Vinceb's picture, the one in the middle, not the bottom left. I'm afraid to accidentally lube the clutchplate, causing it to slip. Or can I just spray right in there, inside the trasmission? Any help would be greatly appreciated guys! |
#32 |
Hi guys! Couldn't wait for anyone's response, just took to it myself this morning... Fixed! Here's how I did it, I guess it's the same as most other solutions found here.
First I lubed the cilinder on the inside of the car, the one pushed in directly by the pedal. That solved the rattling, cracking, squeeking sound. I was still left with a high pitch squeek. I then peeled off the rubber boot on the cilinder in the engine bay. I have a 2003 Yaris hatchback and there it can be found right at the front of the car, just to the right of the engine. The cilinder looks exactly the same as in CTscot's picture and most of the others I found here. I lubed it quite generously with a thick lube (for a winter bikechain) on the rod that comes in and out. I asked my girlfriend to keep pushing the pedal while i was lubing, that worked it in. There was still a squeek coming from the clutch fork itself, the part by the blue arrow in esse10's picture. I pulled out the rubber boot covering that and manoevred the straw of my WD40 can in there. I had to spray a couple times untill I hit the right spot. It started getting less and less and then one well-aimed spray eliminated the sound altogether. I would advice you to just keep trying for a bit, the pivot point is quite deep in the transmission. Don't forget to put back both rubber boots, which takes a bit of wiggling and maybe a screwdriver to push in. By the way, my distributionbelt also made a nasty sound. Just some WD40 again on the bearings of the wheels turned by the belt solved that too. Engine runs smooth and quiet now. Not sure how long this will last: as WD40 is quite thin, it'll probably start to squeek again sooner or later. Matter of getting a better, i.e. thicker and more heat resistant lube I guess. Anyway, hopes this helps someone else as the above posts have helped me. Good luck! |
#33 |
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
can anyone recommend which lube I have sprayed it with white lithuim grease but stil;l
#34 |
1- how can I peel of the red circle area
2- What lube to use I am currently using http://www.screwfix.com/c/auto-cleaning/cat7360001 |
#35 |
All
I find this link looks to me quite useful. http://www.toyotanation.com/forum/13...-fix-pics.html But for me how to remove the clutch fork dust boot by pulling it off. |
#36 |
All,
Update on the above, (I havent use the car for about a week). The squeak is back and I have checked this It is coming from pedal and clutch inside. Can anyone help pls. |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 04:59 AM |
| Way to shorten distance on clutch pedal? | kac | Performance Modifications | 2 | 07-23-2009 07:42 PM |
| squeaky clutch | TickleTimeTim | DIY / Maintenance / Service | 4 | 04-28-2009 12:36 PM |
| Car/engine shake when releasing the clutch pedal | hystria | DIY / Maintenance / Service | 16 | 07-22-2007 08:56 PM |
| Hard clutch pedal ? | hystria | General Yaris / Vitz Discussion | 5 | 05-11-2007 07:12 AM |
