Old 05-13-2016, 03:04 PM   #37
mik23
Drives: yaris 2005
Can anyone recommend any good not expensive Lube / oil / grease that I can easily found in UK for this clutch problem...
mik23 is offline   Reply With Quote
Old 05-18-2016, 05:32 PM   #38
esse10
Drives: 2009 yaris 2 door
lubing
Originally Posted by mik23 View Post
All
I find this link looks to me quite useful.
http://www.toyotanation.com/forum/13...-fix-pics.html
But for me how to remove the clutch fork dust boot by pulling it off.
This is some good info. and good link but space is limited you can't get in there without removing the radiator & condenser. I was wondering if anyone had done the fork lubing without removing the radiator & condenser out of the way.
esse10 is offline   Reply With Quote
Old 05-22-2016, 11:04 AM   #39
mik23
Drives: yaris 2005
update
I uses this on slave cylinder and inside car 20 days no squeek at all.
https://www.tetrosyl.com/tetconnect/..._spray/DTT400-
I also remove the boot rubber and spray inside
Old 05-29-2016, 10:46 AM   #40
mik23
Drives: yaris 2005
ok Gents still a month no squeak clutch pedal smooth not feeling hard / heavy.
TT did the job highly recommended.
Old 05-29-2016, 01:55 PM   #41
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I have had this sqeak for a few years. Its definitely the clutch fork pivot. I have removed the slave and lubed it to be sure its good and the noise did not go away, suggesting the only other friction that can be causing that type of noise.
The idea of spraying willy nilly towards my clutch to get to the pivot does not sit well with me.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-29-2016, 02:13 PM   #42
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
For a while, I thought my clutch was squeaking too, but then realized it was my SEAT! When I pushed the clutch, my body of course was slightly pushed back in the seat, and the seat made a very slight squeak noise. I guess I can't oil the seat! :)
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 05-29-2016, 02:15 PM   #43
mik23
Drives: yaris 2005
You need to identify the source it can be the pedal
Old 05-29-2016, 02:15 PM   #44
mik23
Drives: yaris 2005
Grease it
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
Way to shorten distance on clutch pedal? kac Performance Modifications 2 07-23-2009 07:42 PM
squeaky clutch TickleTimeTim DIY / Maintenance / Service 4 04-28-2009 12:36 PM
Car/engine shake when releasing the clutch pedal hystria DIY / Maintenance / Service 16 07-22-2007 08:56 PM
Hard clutch pedal ? hystria General Yaris / Vitz Discussion 5 05-11-2007 07:12 AM
