Old 04-22-2007, 11:31 AM   #19
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
I have some new balances that are pretty form fitting to my foot so It's a little easier than my work boots (LOL)maybe if I glue like a big piece of plastic to my acc pedal I would close the gap of the brake and the acc a little bit. LOL. but I was thinking about look closely at my pedals today to check out if I can mod it any... but I guess the hard part about the seesawing is pressure or lack there of on the brake...
Old 05-02-2007, 05:24 AM   #20
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
yo drifto, u got pix of ur proj mu pedals?
barebonedvitz is offline   Reply With Quote
Old 05-02-2007, 06:27 PM   #21
YogiYaris
Drives: Blue 2007 Toyota Yaris
For those which have small feet ( such as I), the heel toe technique is most easily accomplished by literally using only your heel and toe. Many people are lazy and try to lay their whole foot on the pedals. Try only using your heel and toe. Before even getting started just try getting your foot placement right and finding an accurate leverage point. Your actual heel to toe axis is the most important step in using this technique.
YogiYaris is offline   Reply With Quote
Old 05-02-2007, 07:12 PM   #22
barebonedvitz
can u take a pic of ur foot placement
Old 05-02-2007, 08:32 PM   #23
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
yes ill take some. ill try tonight.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 05-03-2007, 07:04 PM   #24
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
For no apparent reason, I can heel and toe again! I guess I need to be sitting a little bit closer to the steering wheel.
Old 05-03-2007, 07:12 PM   #25
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
The heel-toe technique was key to me when I used to drift my MX-5. The Yaris, not so much. Also, since I'm so tall (6'3"), the pedal placement made it difficult to really use the technique.
So I came up with a solution. Swap it around. Now I do a toe-heel technique where I use the edge of my heel to hit the brake then flex my foot forward to hit the gas with my toes. I don't know why, but this is a lot easier for me now. The hard part was learning not to slam the brake while blipping the gas.
Ran Kizama is offline   Reply With Quote
Old 05-04-2007, 01:55 AM   #26
barebonedvitz
Dude... this seemed easier for me too.. couldn't quite get the old heel toe as i used in the civic.. but yah.. this yaris is exercising my left-foot braking too..
are u guys able to use the heel toe in auto x wid our cars?
Old 05-04-2007, 10:20 PM   #27
drifto
drifto's Avatar
ok here are the pics of my project mu pedals... sorry for the delay, been workin late these days
07 Yaris LB 5spd
Old 01-05-2017, 10:40 PM   #28
Frank the Tank
Drives: 2007 Toyota Yaris
Bump
I know this is a really old thread but any new info on how to make heel and toe possible with this car?
Frank the Tank is offline   Reply With Quote
Old 01-05-2017, 10:56 PM   #29
tmontague
tmontague's Avatar
I do it all the time now, but it was virtually impossible with stock pedals. I installed Sparco pedal covers and now heel toing is much more doable and realistic.
Old 01-06-2017, 08:05 AM   #30
I heel/toe all the things
Old 01-06-2017, 10:58 AM   #31
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Which ones did you buy? Did a quick Google and eBay search for a combination of Yaris and Sparco pedals, but didn't get any matches.
Heel toe seems impossible with the stock pedals.
On Instagram
On Wheelwell
Old 01-06-2017, 07:00 PM   #32
Frank the Tank
Link please
Old 01-06-2017, 07:46 PM   #33
tmontague
tmontague's Avatar
http://m.ebay.com/itm/Sparco-Settant...900?nav=SEARCH
Old 01-08-2017, 06:47 PM   #34
ern-diz
ern-diz's Avatar
They look nice! Thank you, sir!
On Instagram
On Wheelwell
Old 01-09-2017, 12:51 PM   #35
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
My feet are generally too big, but for me with the lightweight flywheel every time I use the clutch the throttle gets blipped anyways.
Colin Chapman disciple
Old 01-09-2017, 02:29 PM   #36
tmontague
tmontague's Avatar
I should also add that the pedals are not slippery although they look to be so. The black lines are grooves cut into them and they give lateral grip even with snowy wet shoes.
That said, I always bang my feet off as best as I can when I have snow on my shoes and yet to have any issues
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
