#253 |
The connector is located under the dash on the drivers side. Lie on your back and look up under the dash. Closest to the radio you'll see a white connector (is a pretty decent size), unplug that and you'll disable the DRL's.
To make led's your DRL's wire it to your windshield washer fluid 12v wire which is located on the side of the resevoir. This allows you to not have to go through the firewall to access ignition switched 12v power
#254 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Alternatly, you can use a power booster like this (http://www.hidvisioncanada.ca/6v-to-...power-booster/) to convert the 6V DRL signal to the full 15V required.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#255 | |
Sent from my ONE A2005 using Tapatalk |
#256 |
![]() Drives: yaris hatchback 2007 Join Date: Aug 2016
DRLs not working
DRLs on my Canadian Yaris 2007 manual HB no longer work. All other lights are OK.
The DRL started working intermittently and it seemed it might have been related to handbrake operation. Now finally DRLs are never on but the handbrake dash warning light still operates normally. Does anyone know if the handbrake switch has a single contact for both circuits or is it double? If the problem is the DRL relay is there anyway of testing this before replacing it? Expensive replacement otherwise! |
#257 | |
#258 |
The DRL receives full 12v, but the current is pulsed to lower the amount of light produced.
Sent from my SM-G930W8 using Tapatalk |
#259 |
MY HERO! I tought the DRLs are UGLY AF on my Canadian Yaris Hatch.. sooo now, my yellow foglights ARE my DRLs they are 99% of the time ON anyway
#260 |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
DRL
No need to remove any panels.Just fold down panel underneath steering colum,reach up and unclip white harness.
Did this today.Great post though as it indicated exaxtly where box was. |
#261 |
IIRC, on vehicles equipped with fog lights, simply doing this will disable the fogs as well.
#262 | |
Use it to wire up the DRL of your choice. :) Sent from my SM-G930W8 using Tapatalk |
#263 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
#264 |
![]() ![]() Drives: 2007 Yaris Hatch is sold Join Date: Mar 2017
I'm going to do this cause I'm forgetting to turn my lights on at night cause the silly cluster is lit and I sub-consciously think they are on.
maybe without the DRL I will notice quicker. |
#265 |
i agree it is silly! I often see people driving with no rear lights because the DRLs are on. However since it is illegal to drive without DRL in Canada I drive with sidelights on in daylight - when I remember! :-)
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
