Old 02-18-2015, 05:02 PM   #307
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
2007, just over 57k miles.
Other than having the rack & pinion replaced at 40k and the clear coat on the bumpers re-sprayed, it's been smooth sailing.
Old 02-18-2015, 08:33 PM   #308
Kar98
Drives: 2011 Scion tC
Well at 57k it's barely broken in ;) Did you drive over a curb or why did the r&p have to be replaced?
Old 02-18-2015, 08:38 PM   #309
ern-diz
ern-diz's Avatar
The car was involved in a minor fender bender early on when a friend didn't realize I was parked behind her and backed into me. It was a low to no speed impact and I had everything inspected/repaired professionally, so not sure that caused it, but don't know what else might have. Maybe just a factory dud? I opted for the extended warranty, so luckily it only cost me the $50 deductible to have it all replaced by the stealership.
Old 02-20-2015, 02:12 AM   #310
blktiger60
blktiger60's Avatar
Drives: `08 HB S
08 2dr HB
73,300 miles
Bought new in March 2008
no repairs, only oil changes - not counting the recent accident
3-4-18, 92k and still running fine.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 02-20-2015, 03:56 PM   #311
instantninja
Drives: 07 yaris rs
2007 yaris rs 5 door 225,000 km, no major problems, I had an ABS light come on 2 years ago during the spring. Cleaned the connector and it went away.
put on a tooter intake manifold and a 1zz throttle body about 20,00km ago, only issue there is if I don't let the car warm up sufficiently the throttle body gives an over current CEL and limits the rpm to 2000, and that only happens when its below -25. this car has been dead reliable and couldn't be happier with it.
instantninja is offline   Reply With Quote
Old 01-06-2016, 06:54 PM   #312
yak
yak
Drives: 2007 5 dr yaris
2007 5Dr Hatch milage
357km
drive it like I stole it every day
routine maintenance, oil, plugs, air filter cleaning (CAI)
replaced serpentine belt at 265km
yak is offline   Reply With Quote
Old 02-03-2016, 09:42 PM   #313
emgconsulting
Drives: 2007 Yaris Hatchback
2007 Yaris 2dr. Hatchback CE
No issues besides regular maintenance (1 headlight bulb, brakes, tires filters, oil)
165,000 miles and going.
Black mica
emgconsulting is offline   Reply With Quote
Old 02-05-2016, 04:26 PM   #314
Frank the Tank
Drives: 2007 Toyota Yaris
2006 hatch
162,000km
At the dealership right now and the camshaft gear needs to be replaced. Fffaawwwww-k
Frank the Tank is offline   Reply With Quote
Old 02-06-2016, 08:11 PM   #315
zoidberg444
zoidberg444's Avatar
2006 Hatchback, 5 door, 1KR-FE engine.
100,000 miles.
Water pump went bad at 65,000 miles. Made a lot of noise.
Alternator failed at 88,000 miles. Faulty voltage regulator. Drove it around for weeks.
Other than that. A few tyres, brake pads, a battery and an exhaust a bulb or two and servicing. I really can't complain. I drive it like i stole it and it takes me all over the country.
Old 07-08-2016, 07:14 PM   #316
dbosnake
Drives: grey
2008 4 door
168,698 miles and counting
No repairs besides recharging the AC
Sent from my Nexus 7 using Tapatalk
dbosnake is offline   Reply With Quote
Old 07-09-2016, 01:15 AM   #317
rabbito
rabbito's Avatar
drove 3 years..45,000km...battery died at 35,000km...exterior is wearing out such as black plastic trims, wipers, distorted rubber seals
Cosmetic: Toyota red emblem
Old 07-12-2016, 06:55 AM   #318
laurenth
laurenth's Avatar
Drives: yaris
2004 Toyota Yaris 5door Hatchback 1.0 (65hp)
150,000 km (94000 miles)
Some electrical problems like the dome light won't turn on, front windshield wiper liquid pump isn't getting electricity. The headlights turned ugly yellow so I changed them, The little engine that could is purring like it's still brand new.
laurenth is offline   Reply With Quote
Old 07-12-2016, 08:45 AM   #319
Rigaud
Drives: 2009 Yaris
2009 3door HB 121000km.............Front brakes when I bought in at 78000km in Jan. 2014. Other the tuning and moding I haven't had a single issue or part to remove, even the battery is the original. Car doesn't come out winters so this year it's getting TLC over the winter months. Front wheel bearings, water pump, replace the battery...
Old 07-12-2016, 11:19 AM   #320
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
2015 Manual 5-spd SE, manufactured late 2014 France, purchased late July 2015 Colorado, USA. Currently has a bit over 11k miles on it. Only problem(s) thus far:
- Little plastic fins under front bumper, in front of each wheel installed incorrectly @ factory - dealership corrected under warranty.
- Annoying rattle/buzz in drivers-side side air vent on choppy roads or bumps - dealership corrected under warranty.
So far, that's it. Fingers crossed.
Kalispel is offline   Reply With Quote
Old 07-19-2016, 01:31 PM   #321
contraband831
El Huevo
contraband831's Avatar
'07 LB
315K miles
-lots of TIRES! :)
-alternator at about 260k
-Spark plugs (3 sets)
-brake and transmission fluid 240k
-Radiator fan 230k
-battery (2)
currently needs new brake pads and fuel system needs to be cleaned.
Overall this car is great, looking to get a newer model to replace this bad boy.
Old 07-20-2016, 06:13 AM   #322
PlainAndrew
Drives: Yaris 1.5 S-Limited
Yaris 2010 AT
60k
The current problem I'm facing is if it idles in drive and AC on the rpm drops to 500 some times below end up causing a vibration (twice the engine shutdown)
Overall this car is awesome. But can any body help with this problem?
PlainAndrew is offline   Reply With Quote
Old 07-20-2016, 10:07 AM   #323
ern-diz
ern-diz's Avatar
A little over 66k miles in my '07 lift-back and I just had to replace the alternator. Mechanic said it was barely making enough power to run the car. Nine years old and all I've had to replace is the water pump, driver's side axle seal and now the alternator.
Best $12,500 I've ever spent lol!
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
