![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Engine breather filter?
anybody using one these engine breathers on N/A engine? any gain? let me know the detail please, thanks
![]() Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
If you think that provides a power gain you have no idea what it is for.
The only reason to install a vent is if your PCV system cannot keep up with the crankcase pressure. Typically only happens on boosted engines, or sometimes if the motor is doing high-RPM track-days (or if the rings are badly worn). There are some vehicles where the PCV oils will clog up various parts of the engine, and I would consider modifying or removing the system, but the Yaris is not one of them.
I'd spend your money elsewhere unless I am missing something. Cheers. |
i'm pretty sure these filters just leave your crankcase unpressurized. (?) I don't see an advantage except the crank vapors do not get vented to the intake system. I would think you'd want the crankcase to remain pressurized during high acceleration to reduce piston blow-by, and this is the reason I would not use one of these...
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Really Bad Engine Sludge... | monchito18 | DIY / Maintenance / Service | 27 | 05-14-2014 11:47 AM |
| F/S Engine Breather Catch Can | 1NZYaris1 | Items for Sale by private party | 2 | 03-05-2010 10:29 PM |
| Air Filter head fell off! Check engine came on! | Syroyizhka | General Yaris / Vitz Discussion | 23 | 05-06-2009 12:41 PM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
