Old 08-02-2016, 08:43 AM   #1
luisf166
Drives: 2011 toyota yaris sedan 1.5l
Unhappy Click sound when P to D / D to P
There's a click sound that just started happening recently. Lets say I'm going to park my car so ill press the brake pedal and then put it to p, the car doesn't go into park as soon as i put it into p there's a 2-3 second delay my car is moving back a little and that's when the click occurs. is this normal ? this never happen before. then sometimes when I'm in park then reverse then go into drive there's that click again.
luisf166 is offline   Reply With Quote
Old 08-02-2016, 01:22 PM   #2
bronsin
bronsin's Avatar
Not normal.
Have you checked the oil level in the transmission?
Old 08-02-2016, 02:25 PM   #3
luisf166
i just checked the oil level of the transmission. its still good but its a little higher then its supposed to be.
Old 08-02-2016, 02:48 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Sounds like a defective BTSI solenoid. Try the manual park-lock override and see if it fixes it not going in/out of park.
It's a little cover on the top of the PRNDL bezel. Pop it off with a screwdriver or your key and poke your key into it. That will let you get out of park without pushing the brake pedal. If that allows the lever to move without getting stuck/bound up, then you've probably got a bad solenoid or brake switch.
Old 08-02-2016, 05:05 PM   #5
luisf166
Well i pop the little cover and tried it and i was able to move the gear shift without getting stuck
Old 08-02-2016, 05:08 PM   #6
CrankyOldMan
Ok. The next check is to have someone put their head by the lever and then press the brake pedal. You should hear the solenoid firing right when the brake lights come on. Maybe a little click or bump.
Sent from my MotoG3 using Tapatalk
YARIS 2005 Rattling sound mik23 DIY / Maintenance / Service 6 05-15-2016 05:34 AM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
CLICK sound when putting Automatic transmission from D to P and vice versa Swallow General Yaris / Vitz Discussion 8 05-03-2010 07:25 PM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
