Old 05-30-2016, 05:25 PM   #1
KenTK808
Drives: 2014 Yaris LE
Removing Rear Wiper Motor
Does anyone know how to remove the rear wiper arm from the motor on the rear hatch? I have a 2014 LE and it seems to be stuck on there. I took the 10mm nut off but the arm seems to be still held onto the motor by something. I'm removing it for aesthetic purposes. I found a plug that goes in the place of the wiper.
Your help is greatly appreciated.
KenTK808 is offline   Reply With Quote
Old 08-09-2016, 02:58 PM   #2
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
You should be able to wiggle the wiper blade off; just gently pull and wiggle and the blade should pop right off.
- Remove the inner plastic trim from the trunk. In my 2007, I just gently went around the edge with a screwdriver and popped the plastic clips off. They are not visible so pry gently.
- There is a plug you'll have to unplug as well. It should be the type you pinch to unlock.
- Remove the wiper motor, should be 3-4 bolts tops.
- Slap everything together, install your plug, and you're good to go.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 08-09-2016, 11:33 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
yeah, there isn't anything else holding the arm to the motor. Just corrosion.
Old 08-10-2016, 02:12 AM   #4
KenTK808
I used a small gear puller tool to remove it. It's the only way to do it without denting shit.
Old 08-10-2016, 09:28 PM   #5
bladesmith6
Drives: 2007 yaris HB
you can take the arm off with a caulking gun, hook the front circle around the arm and squeeze the trigger until the plate pushes against the stud, boom, pops right off no damage. all hail macgyver.
bladesmith6 is offline   Reply With Quote
Old 08-10-2016, 10:01 PM   #6
Bluevitz-rs
Changing Rear Wiper Arm barfart UK 6 04-24-2021 11:41 AM
P1 rear wiper arm on P2 Chariz Cosmetic Modifications (Exterior/Interior) 1 10-12-2014 06:08 PM
Rear Wiper "Coverage" Problem Solved Onwrdigo Third Gen Yaris General Discussion 5 06-20-2013 06:48 PM
Removing Rear Seat bronsin DIY / Maintenance / Service 4 04-11-2011 02:34 PM
How-To: Liftback Rear Wiper Arm - Full Pivot! Chris07LB DIY / Maintenance / Service 5 07-24-2009 03:08 PM
