![]() ![]() Drives: 2014 Yaris LE Join Date: May 2016
Removing Rear Wiper Motor
Does anyone know how to remove the rear wiper arm from the motor on the rear hatch? I have a 2014 LE and it seems to be stuck on there. I took the 10mm nut off but the arm seems to be still held onto the motor by something. I'm removing it for aesthetic purposes. I found a plug that goes in the place of the wiper.
![]() Your help is greatly appreciated. |
DKDC
Drives: Yarlet Join Date: Aug 2006
You should be able to wiggle the wiper blade off; just gently pull and wiggle and the blade should pop right off.
- Remove the inner plastic trim from the trunk. In my 2007, I just gently went around the edge with a screwdriver and popped the plastic clips off. They are not visible so pry gently. - There is a plug you'll have to unplug as well. It should be the type you pinch to unlock. - Remove the wiper motor, should be 3-4 bolts tops. - Slap everything together, install your plug, and you're good to go.
(dick measuring info goes here) |
yeah, there isn't anything else holding the arm to the motor. Just corrosion.
I used a small gear puller tool to remove it. It's the only way to do it without denting shit.
you can take the arm off with a caulking gun, hook the front circle around the arm and squeeze the trigger until the plate pushes against the stud, boom, pops right off no damage. all hail macgyver.
| Changing Rear Wiper Arm | barfart | UK | 6 | 04-24-2021 11:41 AM |
| P1 rear wiper arm on P2 | Chariz | Cosmetic Modifications (Exterior/Interior) | 1 | 10-12-2014 06:08 PM |
| Rear Wiper "Coverage" Problem Solved | Onwrdigo | Third Gen Yaris General Discussion | 5 | 06-20-2013 06:48 PM |
| Removing Rear Seat | bronsin | DIY / Maintenance / Service | 4 | 04-11-2011 02:34 PM |
| How-To: Liftback Rear Wiper Arm - Full Pivot! | Chris07LB | DIY / Maintenance / Service | 5 | 07-24-2009 03:08 PM |
