Old 04-24-2007, 12:02 AM   #19
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
Originally Posted by driver centric View Post
Very nice setup nurburgring, I actually looked into that size tire but choices were very limited.
Choices are limited, but you do get some very good tyres like Dunlop SP MAXX and Continental Sports Contact 2 . The Dunlops grip like crazy wet or dry, and are as quiet as normal comfort tyres.
nurburgring is offline   Reply With Quote
Old 04-24-2007, 12:06 AM   #20
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Well 501 had TRD struts put on his LB, aren't they shorter than the stock pieces? And obviously, they weren't meant to be used with DFs, which are lower than the TRD springs. So I guess it makes sense to me. Why else would the front of his car be sitting up so high? He said it evened out after the bumpstops were cut...
Drop pic of DF210s from Tanabe's Web site for reference:
The front looks pretty even with the back to me...
No the TRD struts are not any shorter. Cutting the bumpstops or not has no bearing on the ride height. The springs just settled, that is why it got a bit lower.
Mine is actually almost a 1\2 inch lower than the pics above now that the springs have settled.
Old 04-24-2007, 12:14 AM   #21
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
Interesting, here is his post from one of the threads discussing bump stops. He seemed to have noticed a difference immediately after they were cut.
Originally Posted by 501 View Post
when i had my set up(df210-trd struts)installed they had forgot to cut the bumpstops. when the car was set down the front was still at stock hieght, which i could tell that the strut was sitting only on the bumpstop. i had to drive for a week like this, the ride was harsh up front and the car wanted to skip around in turns if pushed at all. after the bumpstops were cut the front end dropped into its travel and the ride was night and day better. now the car does not bottom out every where like before.
But I guess it doesn't matter anyway because I'm keeping the stock struts for now until we get some more aftermarket options. And I'll be cutting the bump stops per the DIY available on the site.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 08-13-2016, 07:19 AM   #22
Haad Sheikh
Drives: Toyota Yaris Hatch '09
Man are you using lowering springs at that time?
I'm looking for 16s for my yaris and I don't want to lower it. At least not now. My main goal is to finish that fucking wheel gap and giving a proper look to my car at the same time.
Haad Sheikh is offline   Reply With Quote
Old 08-13-2016, 10:09 AM   #23
Wow, necro after over 9 years. Good luck in getting response to your question.
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
