Drives: 06 YRS 3 Door Hatch Join Date: Sep 2016
$617 for Service, $320 for rear bearing. Value?
- Synthetic oil
- Serpentine belt replaced - Front pads - Machined front discs - e-Rego inspection - Number plate globe - Revalved spare tire - Wheels rotated and balance $617 They also quoted $320 to replace a failing rear wheel bearing Reasonable? |
Typical I guess. I assume a dealer did the work?
Always request to see the failed part when having something replaced. Or say "Show me why what you say is defective" before they do the work. Helps keep them honest.
I don't know about you bronsin, but personally I find it hard for a North American to comment on work being performed in Australia.
Wollongong must be an absolute paradise to live in!
It's always less if you can DIY no matter where you live.
Eh?
![]() ![]() ![]() ![]() Join Date: Feb 2010
I just had to replace my drivers side rear wheel bearing today at 112,000 miles, which is a bit premature to me. Local garage wanted $470. I did it myself of course. I opted to go with the better "Timken" bearing vs. the original equipment "Aisin" bearing that failed. The Timken bearing was $150 since I have the anti skid capabilities. Cheaper brands could have been bought for $45...but I trust the Timken brand. It's about a two hour job...not so much due to difficult to do, but just difficult to pull, or break loose the old assembly.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
What time/distance service was it? Some services are more involved and eexpensive than others. I just had the 48 month service done last! week. With air conditioning deodorise and disinfect plus a new filter, it cost $867.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Like I said it was at 112,000 miles. What you had done, a PM, is apples and oranges when comparing to what I had to do as an unscheduled repair.
Better to DIY or buy your own parts and have your trusted mechanic install it.
Sent from my SM-J727T using Tapatalk |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Alternator Bearing | barryware | DIY / Maintenance / Service | 7 | 11-23-2013 06:33 PM |
