Old 09-06-2016, 03:59 PM   #1
sim085
Drives: Vitz 2007
Engine oil question
Hello, I have a Vitz from 2007 with 1.3 Engine and automatic transmission. I do not know if this is a problem or normal for the car.
Last March when I curved the oil light turned on. I checked with the stick and found that the oil was very low. I had taken the car for a service (which included an oil change) a couple of months before so I took the car to a mechanic because I thought it was leaking. The mechanic told me that these vars (Vitz 2007) were known to burn oil and he topped the oil again.
Now, August, after around some 5000KM the oil light turned on again when I curved. I checked the oil using the stick and found that again it was very low. I have now topped it again.
However I was wondering - is this really normal?
sim085 is offline   Reply With Quote
Old 09-07-2016, 01:54 AM   #2
bairjo
no.
Old 09-07-2016, 02:41 AM   #3
sim085
Drives: Vitz 2007
Originally Posted by bairjo View Post
no.
What might be the issue then?
I will plan a visit to Toyota. However it would help to know what the problem might be so that I'll know what they are speaking about.
Old 09-07-2016, 02:56 AM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
You either have a leak, which shouldn't be too hard to find, or you are burning that oil, which would indicate engine problems, most likely valve guides or piston rings. How many miles on the engine?
Old 09-07-2016, 11:33 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
check your dipstick more often so curving won't be the indicator of low-on-oil
Old 09-07-2016, 12:37 PM   #6
sim085
Drives: Vitz 2007
The car has 85,942 Km.
How can I find if it has a leak?
Is there any other indication to know if the problem is with the engine?
Old 09-07-2016, 01:49 PM   #7
NYC-SE
NYC-SE's Avatar
At that mileage I wouldn't think engine problems but it's still possible. Is the car performing right otherwise?
As for a leak do you see any oil an the ground after leaving the car parked overnight? Best to just get a flashlight and inspect the engine from top and bottom. You should be able to see evidence of a leak if one is present.
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Really Bad Engine Sludge... monchito18 DIY / Maintenance / Service 27 05-14-2014 11:47 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
