Old 09-09-2016, 05:32 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Nitrous Oxide Modification?
does anybody have nitrous installed inside their yaris? how is it?
a shop charged me $1,000 flat for nitrous kit and installation..is this good price?
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 09-10-2016, 11:49 PM   #2
SirDigby
Drives: 2007 yaris 3 door
it depends on what kind of a system is installed. the best way is to install a system where the nO2 is injected with the fuel at the injector. it should work great. what brand is it? how big is the bottle? the system is pretty much: a bottle, lines, a controller, solenoid system (my require fuel modification) or injector system (more expensive, fuel modified), and sometimes a WOT switch. they are pretty simple, installing takes a couple hours. tuning is pretty basic too.
these pictures look like fogger systems. they might require fuel modification....
Old 09-14-2016, 12:28 AM   #3
alias06
Drives: 2008 Red Toyota Yaris
read this thread...http://www.yarisworld.com/forums/showthread.php?t=12203
alias06 is offline   Reply With Quote
Old 09-14-2016, 07:00 AM   #4
rabbito
rabbito's Avatar
Originally Posted by alias06 View Post
yeah i was expecting that too..30-50hp, not more than that with stock internals..thanks for the info 🙄🙄🙄🙄
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Custom Intake manifold/w 1zz tb / direct port nitrous blacksandiegovitz Items for Sale by private party 28 11-23-2010 09:57 PM
Nitrous - Safe Shot System - a safer alternative fuji Performance Modifications 15 04-17-2009 05:24 PM
Talked to my mechs about nitrous. staticorex Performance Modifications 29 10-26-2008 05:33 PM
Nitrous Oxide Systems, Yaris on the Bottle CASTREX Performance Modifications 20 07-15-2007 11:40 PM
