Old 09-11-2016, 04:21 AM   #1
Garth g.
Drives: 07 Yaris 2dr hatchback
Cv joint replacement 07 2dr
Never done cv joints before. Bought my car in January they were torn and clicking, mechanic changed them cheap after market ones. $110 a side. The passenger side accumulates grease on the boot everytime I change the oil. I always wipe it off it comes back. I noticed I have to change the stabilizer links, the one on the passenger's side is torn. I ordered mevotech ones. I'm starting to work on this car myself if anyone has any experience with this I would appreciate your feedback.
Garth g. is offline   Reply With Quote
Old 09-11-2016, 11:04 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You'll need a few specialty items for the axles:
* De-staking tool for the spindle nut
* 30mm 12-point socket
* Retention clips (OEM part 90521-26004, 2 ea.)
Common tools/items
* Pry bar to get the axles out
* Breaker bar or impact gun
* Gear lube or ATF, as appropriate
General advice
* The hex sockets on the end links will likely strip before you break the nut loose. Soak them in penetrating oil a day or two in advance. Be prepared to cut them off.
* You will need an alignment afterwards
* Removing the wipers and cowl is optional, but makes accessing the top of the strut easier. You will need a 17mm a through-hole socket wrench or offset box wrench.
* Jack stands at a minimum, car lift is ideal.
There's probably something else I'm missing. I've done it several times so I'm kind of on autopilot.
Old 09-14-2016, 04:22 AM   #3
Garth g.
Thanks for the guidance. I didn't change the cv half shaft assembly's yet, did the sway bar links though. I soaked the nuts and bolts a couple of days with w-d40 and liquid wrench 🔧. I also cracked them first with a breaker bar, then used a gear wrench and a 6mm Allan key. I almost stripped the last nut, good thing I didn't I wasn't prepared. I torqued them to 59ftlbs,not sure if that's accurate (found a chart on my phone) I think the grease that's on the cv boot is coming from somewhere else like I said it's there sometimes and there is no clicking or damage. Had to start this job at 11pm work crappie hours. I feel enthused.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 10:45 PM
Rear Speaker Replacement 2DR Hatch salty3142 In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2015 12:38 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
