![]() Drives: Toyota Yaris 2009 Hbk Join Date: Oct 2016
Bolt identification
Hi there,
I was doing an oil change on my 2009 Yaris Hatchback (Auto) recently. This was my third time doing it. I completed the change successfully in the end. However, when I first went under the car, in a moment of madness I loosened the wrong bolt. The one in question was a silver bolt directly next to the oil filter. It must have been the same size, because it fit the same socket. Upon loosening it, there was a liquidy bubbling, a release of some oil, and a chemical smell. I realized my mistake within a few seconds and closed it again, but I wanted to figure out what exactly I did and whether it could be a problem. There was a noticeable amount of oil in the catch pan, but not a large amount by motor oil standards. I tried to find a diagram online or something to identify it, but I haven't been able to. The manual doesn't seem to have that level of detail either. If anyone could tell me what I opened, I'd very much appreciate it. Thanks! |
From the sound of it, I would guess you found the bottom of the A/C compressor and let some gas out. Was the oily stuff dyed yellow?
So long as it is tight (whatever bolt it is), you haven't done any harm. If it is the A/C, you may want to get the pressure checked. Cheers. |
I believe it was yellow. So it sounds like that's probably it then.
Thanks for putting my mind at ease. :) |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 06:54 PM |
| Broken Control Arm Bolt | Sirius-XM | DIY / Maintenance / Service | 4 | 02-29-2016 09:27 PM |
| Rounded bolt replacing belt | thekatiel | DIY / Maintenance / Service | 13 | 09-29-2014 07:39 AM |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 04:18 PM |
