![]() Drives: Yaris Hybrid Join Date: Oct 2016
Yaris DRL Halogen Bulb LED replacement
Hello,
my wife's Yaris has a factory build DRL using however halogen bulbs. I would like to change the bulbs with plug and play LED replacements. Does someone know and use LED bulbs which will fit with no issues? What I was able to find in the owners manuals is that the bulb is Wedge base bulbs (clear), but it has no dimensions no nothing... All suggestions are welcomed. |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
the DRL is the high beam/low beam bulb at low voltage. (in the US) the Wedge bulb is used during normal lights operation. the wedge bulb is a size 194. the high/low is a 9003 or a H4
Here in Europe, DRL lights are using separate bulbs.
I will give it a try to see if I will be able to find something with Wedge bulb size you gave me. Thanks for the hint. Last edited by todorakiggg; 10-18-2016 at 03:38 AM. |
Drives: Yaris 1.5 Join Date: Oct 2016
i recommend you to use the retrofit projector from the retrofit source
you will get the perfect beam :) |
take a picture for all to see.
Real picture I can provide later... (the car is with my wife)
So I am attaching a screenshot example from the Yaris manual. |
OK, this turns out to be double filament wedge bulb...
So it looks like, it is type 580 with bulb size 7443. (even though I am not 100% sure) I am just wondering, why is this info not on the user manual.... |
oh, I didn't know it was such a new car. the bulbs I gave were for 2nd gen...
Solution found. These bulbs fitted just perfectly and working very well. Instalation took me 3 mins, plug and play replacement of the factory bulbs and that was all. Quite satisfied with the end result.
http://www.autobulbsdirect.co.uk/744...edge-Bulb.html |
Finally after some reading I have ordered these bulbs.
Installation was very easy, just plug and play, it took me around 3 mins for both bulbs. The result is very, very satisfactory. The light is amazing, no error lights no nothing. Even now I think that the turn signal is more visible, because it is clearly different from the original yellowish DRL light. As of now I can highly recommend the bulbs, but I got to admit, they are expensive... |
Solution found and works perfectly well.
If someone is interested, please let me know and I will send you more details for the LED bulbs I've used. (I tried twice to post the link here, but I am still waiting on the moderators to approve it, maybe they didn't). |
| Toyota Yaris 09 REG P2112 - Throttle Body Replacement Help | Toastie | DIY / Maintenance / Service | 13 | 05-08-2016 04:28 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| 2012 Yaris DRL Light Install--Hand Made-- | martindimitrof | DIY / Maintenance / Service | 14 | 11-21-2012 02:44 AM |
