Old 02-09-2016, 04:25 PM   #1
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
Yaris 2015 Cruise Control & Speed Limiter in one stalk
And ASL stands for The Adjustable Speed Limit. Hello to everyone, this is my first thread I ever made, anywhere.
Big "thank you" to CTScott, who inspired me to make things his way.
I own Yaris 2015 1.33-VVTi Active 1NR-FE that comes in package without Cruise Control and ASL. And that's what I thought...
After thoroughly examination of Cruise Control threads here on YarisWorld, I had to test is Cruise Control System really there (clutch Start and End position switch factory installed).
So after short connecting pins 3 & 4 (z7 connector under the steering wheel airbag) I got the Cruise Control light on.
Green light to obtain stalk . I knew if there was Cruise Control hidden, there has to be speed limiter (ASL) as well. This is a nice feature for local driving where you can easily overdrive and then... I found almost nothing about this feature on the internet (for Yaris and on forums). It's command button is located on steering wheel's right side.
First I had to make sure that wire for ASL exist. In diagram, it is light green wire on position 11 of F5 connector. Since this is a manual transmission, shift pad installation is not present.
And again, using CTScott's method of examining the F5 connector hidden under the steering wheel cover, there it was, light green wire on pos. 11.
After short connecting pins 11(ASL) and 2(ECC) I got the ASL light on (with ignition switched to ON)
Looking at the diagram, and later by examining pins, position 11 goes to position 4 of the z-2 connector in steering wheel, but of course, no wiring
I was really hoping that there was a hidden button on the PCB, but of course there is not...
To make this work, you need complete set of wiring and steering commands that is sold as a one part and price...
Position is present but no wire. They could supply those LED's too, Nissan Micra has them... Btw this yellow ECC connects to the pin5(z2) that connects to the empty pin 12(f5)???
Considering the investment and to find it second hand (holy Grail is more common to find) I was saying goodbye to ASL .
And then I thought, how to implement ASL into the CC stalk?
What I intend to do is to install a small push button in front of the stalk, (bit bigger and black)
pull the wire and then use pins 1 and 4 of z7 connector. (Pin 2(z7) is the horn as well as the blue wire pin 1(z2))
To make this work, I will have to move the light green ASL wire from the pin 11 to the empty pin 7 of f5 connector.
Pin 7(f5) connects to pin 1(z7) and pin 4(z7) is already ECC.
Gagi is offline   Reply With Quote
Old 02-09-2016, 07:59 PM   #2
Nice!
The stalk has no space for an extra switch. I would either look for a junkyard steering wheel with the ASL switch present or maybe add the switch someplace on the dash or steering column cover instead.
Old 02-11-2016, 09:05 AM   #3
Gagi
Gagi's Avatar
So there isn't any space inside of this part of the stalk? What is inside? I was hoping to install this type of pushbutton. It requires 12mm hole (less if you put thread on) and goes 9mm in depth when pins are bent.
Old 02-11-2016, 09:08 AM   #4
Gagi
Gagi's Avatar
Rewired
Old 02-29-2016, 07:49 AM   #5
Gagi
Gagi's Avatar
While I'm awaiting for my stalk to arrive and figuring out how and where to install that 5th switch for the ASL function, I spotted that there is a stalk on the market with "mode" option. For me, that would be the best solution to use as the ASL switch.
What I also spotted is that any stalk has three pins. What I would like to know, if anyone knows, is there a fourth "empty" movement toward the instrument panel on the normal stalk, and will it make a connection on the middle stalk pin?
Anyway, this is my final option, to use this middle pin, with oncoming stalk, or with the new one with "MODE" option.
Old 03-02-2016, 08:05 AM   #6
Gagi
Gagi's Avatar
Stalk has arrived and I can confirm that all our stalks are four axis joysticks with locked fourth movement toward instrument panel.
Everything inside is completed in the factory, you just have to cut three small plastic locks that prevents stalk to move 4-axis.
And yes, it is momentary switch that connects to pin 2 on the stalk side. Cheers.
Forgot to mention, as a third wire I took two unused from steering column (because of female terminals), but much better is to obtain another cable, it's plus 3$.
Old 03-02-2016, 08:20 PM   #7
Gagi
Gagi's Avatar
Finally, everything went as planned.
Cruise Control and Speed Limiter in one stalk, minimal investment.
Old 03-03-2016, 02:50 AM   #8
mikeybee
Drives: Yaris 2012 Hatchback
Nice! I just did this using a replacement button pad on the steering wheel - see the other thread on 2012+ cruise control...
Your solution is a good alternative if getting hold of the factory button pad is proving difficult, which it certainly was for me...
Mikeybee
mikeybee is offline   Reply With Quote
Old 03-03-2016, 03:00 AM   #9
Gagi
Gagi's Avatar
Yes indeed is difficult. At the moment (Mar-03-2016) there is one on ebay. I had the same experience with dealers (What?, Why?, it is impossible to retrofit that...)
Old 05-18-2016, 04:45 AM   #10
panayiotis
Drives: yaris 2016
for anyone who want limit switch i found it for $60 on ali.(brand new)if you want it send me a message.
panayiotis is offline   Reply With Quote
Old 10-26-2016, 06:36 PM   #11
amit87
Drives: MY63 Toyota Yaris 1.33SRManual
HI guys.... I want the ASL button for my steering wheel but want to pay minimal.
This is quite hard to come by and I use speed limiter a lot in work hire cars.
When I get Bluetooth phone calls I ALWAYS pick up and hang up from the touch&go and not the steering wheel buttons.
So for £free I am thinking to switch couple pins around and set either the "call answer" or "call end" button to activate the speed limiter. What do you think?
PS great info.... could not be able to do myself without the above wiring diagrams.
If someone can find me a switch or a part number which I can try and ask toyota for, it would be better as I'm a massive OEM fan.
amit87 is offline   Reply With Quote
Old 10-26-2016, 06:51 PM   #12
amit87
What's ones opinion on soldering on my own "tactile switch"?
I have couple spare wire pins from an old project (added OEM reverse cam to my audi s3 too) to make my own additional wire. Soldering looks relatively simple.
Old 10-27-2016, 02:27 AM   #13
Gagi
Gagi's Avatar
First, I would like to strongly advise you to force yourself with usage of steering wheel phone commands. It was very stupid from Toyota to leave this touch screen phone commands available while the car is moving. But...
Of course, you can use one of these buttons, but you will have to remove one of two resistors on pcb and make a short connection on its place.
You can also modify your cruise control stalk, and that is completely free, as you would like it to be. And it works perfectly.
If you are the OEM fan, there is complete part China made that you just plug in place. There is no separate button as a part, you buy complete set of commands, together with wirings and connector. With this part you don't have to change place of ASL pin.
Old 10-27-2016, 02:39 AM   #14
Gagi
Gagi's Avatar
Yes, if your car isn't under some kind of warranty, you can solder it, or put some nice switch on the existing blind button cover. If your pins are not suitable for Toyota, you can find them here: https://www.aliexpress.com/item/1674...608.0.0.UQFBzg
Old 10-27-2016, 03:05 AM   #15
amit87
Thanks for the quick reply. Why do you think I need to remove one of the two resistors? Would the ASL button not need a resistor?
It's also a shame about the LED lights.
Thanks again.
Old 10-27-2016, 03:25 AM   #16
Gagi
Gagi's Avatar
Thanks again.
No, the ASL works as a direct I/0. You may try without removal of resistors. Maybe it will still work.
Old 10-27-2016, 04:07 AM   #17
KenTK808
Drives: 2014 Yaris LE
Wait, If I have a 2014 without the steering wheel buttons for the phone, can I add it? Is there just a connector under the steering column?
KenTK808 is offline   Reply With Quote
Old 10-27-2016, 10:10 AM   #18
amit87
Might try this this weekend and get back to the forum on findings
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-02-2009 11:04 PM
