Old 11-07-2016, 09:40 AM   #271
3cyltrbo
Originally Posted by ArmstrongRacing View Post
Yes the 3zrfe has almost the same demensions as the 2zr, The limiting factor being the ECM
you have my interest piqued
can you explain a little bit what makes the ECM the limiting factor?
3cyltrbo is offline   Reply With Quote
Old 11-14-2016, 01:22 AM   #272
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Because we don't have a USDM 3zrfe, I have no service manuals for it either to verify wiring compatibility
ArmstrongRacing is offline   Reply With Quote
Old 11-14-2016, 01:40 AM   #273
ArmstrongRacing
Data doesn't lie
*With the help of other YW members, I have started a collection of 2ZRFE parts to make everyones swap a little easier, just contact me for details!*
Old 12-14-2016, 09:39 PM   #274
jimmykicker
Drives: 2009 Scion xb
Ok. This is a hijack but guys I am stuck! I have a Scion xD 5 speed and the transmission has given up the ghost. Replacement transmissions are incredibly expensive or impossible to source. I have been chatting with a fella that said that the Yaris is bolt in although it is a little lighter duty and requires the Yaris axles that it should otherwise fit without modification. I'm in a real right here and really need your expertise. Please forgive the hijack. It just looks like a good active thread.
Thanks in advance.
jimmykicker is offline   Reply With Quote
Old 12-14-2016, 09:50 PM   #275
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thanks in advance.
You'd be better off starting a new thread (mods, can you move the post?) so that the info doesn't get diluted. Yes, this is a very active community and this thread in particular has been hot over the last year. ;)
That said... Do you know what is specifically wrong with it? The only difference internally that I'm aware of is the differential and ring gear. If it's the synchros or one of the gear sets, you can (I'm 99% sure) use a Yaris as a donor for parts. If you swap the whole gearbox, you will indeed have to use Yaris axles, but that puts you in the bind of having to swap hubs and brakes--not something for the timid. You might be able to use the inboard stubs from the Yaris with the xD shafts, but that's uncharted territory.
Old 12-16-2016, 09:19 PM   #276
ArmstrongRacing
Data doesn't lie
Honestly I would just fix your trans, these gearboxes are simple. (Heading over to thread to comment)
Old 01-02-2017, 01:57 AM   #277
ArmstrongRacing
Data doesn't lie
An update for those following...
https://youtu.be/IPyHlPJDrOM
Old 02-15-2017, 01:07 AM   #278
ArmstrongRacing
Data doesn't lie
UPDATE:
Our first autocross test day was a success, the car is so quick now!!
https://youtu.be/eniW1ZNv20k
Old 02-15-2017, 10:53 AM   #279
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
The production value / editing in your vids has consistently improved; nice job.
On Instagram
On Wheelwell
Old 02-15-2017, 11:33 AM   #280
CrankyOldMan
Are you running as E Prep, or is that for SCCA club racing with E Production?
Old 02-15-2017, 01:18 PM   #281
ArmstrongRacing
Data doesn't lie
EP Because the car has no interior. I regret removing it but after 10 years of daily driving with kids, it was pretty trashed. Plus with it gone the cage install will be easier
Old 02-15-2017, 01:43 PM   #282
CrankyOldMan
I can't find the part in EP that allows engine replacement. =P
Old 02-15-2017, 02:10 PM   #283
ArmstrongRacing
Data doesn't lie
Yeah....I just got a message about that on FB.....even though I asked several people I guess it's still not correct....but it's arguable because it's a Toyota engine....If I must put it to XP that's fine too.
Old 02-15-2017, 09:49 PM   #284
CrankyOldMan
I think it would just be E Mod. /iono
Old 02-16-2017, 05:57 PM   #285
ArmstrongRacing
Data doesn't lie
Ok. So after discussing the classes with other seasoned veterans, We are going with XP
Old 02-16-2017, 08:03 PM   #286
CrankyOldMan
Lol, can you even get trophy points for that? :D
Old 02-16-2017, 09:09 PM   #287
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'm more of a Mac guy but I've found Windows 7 is a pretty good upgrade from XP
Old 02-17-2017, 11:31 AM   #288
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
