11-20-2016, 05:09 AM | #1 |
Drives: Yaris Join Date: Feb 2015
projector retrofit DIY wiring issue
Recently, I made DIY a projector lens for my headlight which is 9003 to singal H1 bulb
I tired to use the HID low beam wire to low beam(+ -) and retrofit reflector + to high beam I realized that when I turn on high beam switch, there is no power to low beam, so the retrofit reflector is on but no light from low beam (no any light) Therefore, I tired to use 4 pin relay, 86 to high beam switch from original socket source, 85 to battery - , 30 to battery +, and 87 to low beam wiring. When I turned on the high beam, the low beam wire(20awg) smoked and burnt. Also, all 4 pin wire are 16 awg Did I do something wrong? Is there any other way to make it works except making a switch for retrofit reflector? |
Tags |
9003 to h1, diy, wiring |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 467 | 10-18-2022 10:20 AM |
Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
Relay Wiring for DIY LED Daytime Running Lights (DRL) | zuberio | DIY / Maintenance / Service | 20 | 07-07-2011 08:02 PM |
Two DIY wiring requests. | Midnight Drifter | DIY / Maintenance / Service | 1 | 03-03-2011 09:05 AM |
