Old 09-30-2014, 10:44 AM   #487
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Originally Posted by Shinare View Post
I want this eBay Android Unit but wondered if anyone had any experience with these kinds of things? Was going to go the Nexus 7 route again but figured if these are already all set up and better... and I would really like a back up camera.
Or this one seems cheaper.
Old 09-30-2014, 11:12 AM   #488
Shinare
Shinare's Avatar
Think Im just going to do the Nexus 7 install again, heh.
Old 12-21-2015, 01:49 AM   #489
BennyLava
Drives: 1987 Silverado
Has anyone else had the bluetooth die? And what did you do?
Just get a new, separate bluetooth system?
Old 04-08-2016, 02:28 PM   #490
ercdvs
Drives: 2010 Yaris
Going to revive this... because i think i want one of the updated units.
is everyone still happy ?
ercdvs is offline   Reply With Quote
Old 04-09-2016, 12:26 PM   #491
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
I had mine for less than a year. The Bluetooth stops working once radio warms up and gets fuzzy like there's no signal until you restart the unit. Finally a few weeks ago the whole unit just died it will go to DVD mode randomly whenever it wants then fail because there's no disc inside and this will repeat over and over. I'd never recommend anyone to purchase this radio and for the price you can get way better.
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 04-17-2016, 01:11 AM   #492
ercdvs
Drives: 2010 Yaris
I ended up installing a joying 7" LCD unit this weekend, so, we will see how that works out
Old 04-17-2016, 08:11 PM   #493
ercdvs
Drives: 2010 Yaris
...aaannnnd it's going to go back. Equalizer doesn't work, radio reception is poor on some stations. I also cant get around 18 presets, no more, no less. Also the screen protector is leaking off and bubling, and I can't remove it because it's under the bezel.
Oh and it's 103mm vs 100 so I can't quuiiiite get it to fit under trim
Old 06-29-2016, 02:21 AM   #494
09Max
Drives: 2009 Yaris 4 door sedan
Joying bluetooth receiver
Hi,
I am looking to install this in my 2009 4 door yaris:
JOYING 7" Latest Android 5.1 Lollipop Double 2 Din Car Stereo Quad Core 1024*600 Head Unit Bluetooth Touch Screen GPS AM/FM Radio Receiver Support Steering Wheel/Backup Camera/4g/WiFi/1080p
Anyone else tried this unit ? Any issues ?
Thanks !
Gary
09Max is offline   Reply With Quote
Old 06-30-2016, 12:30 PM   #495
ercdvs
Drives: 2010 Yaris
Yes. It sucks. I had a very similar model an it was a bitch to upgrade / use and the screen was pealing.
Sent it back
2010 hatchback
Fog lights, Kenwood touchscreen, backup camera
Old 06-30-2016, 07:35 PM   #496
ercdvs
Drives: 2010 Yaris
To expand on this:
Navigation sucked, the included app would always lock up, and I never got a reliable usage of google maps, and I would just use my phone in any case.
After a firmware update to fix an issue I had with Bluetooth, the dimmer function no longer worked with my headlights, and in fact was removed from settings entirely.
The antenna connector,as well as the microphone interface, was very poor. And I got crap quality. The radio tuner app was poorly designed. I think you are also unable to just get another one because it's baked in
The internet is rife with similar reviews and even fixes involving cutting traces and adding solder I am convinced all glowing reviews are fake or special units getting the best qc
Honestly avoid it. Same goes with all of them, joyig, pumpkin, etc.
2010 hatchback
Old 08-19-2016, 05:44 AM   #497
BennyLava
Well I can say that I didn't have most of the problems that you later guys are complaining of. But the bluetooth function on mine is completely dead.
We all already knew this really isn't the highest quality unit out there, although don't get me wrong, I'm not defending it. But when you've got $800 and $1200 units available from reputable brand names such as pioneer and a couple others, I can't say that I'm real surprised to see that the quality control on these units wasn't up to par.
Can anyone recommend one of these types of units that's really high quality? One where you can actually scroll fast through an audiobook or radio show that you've put on a USB flash drive, and inserted into the USB port to listen to on the radio in the car. And it would be really nice to be able to delete stuff off of the flash drive, from the screen. Also that has a good GPS program and bluetooth that actually freakin' works.
Anyone know of a unit like that?
Old 08-19-2016, 01:07 PM   #498
Kar98
Drives: 2011 Scion tC
No deleting stuff off your USB drive via screen, but these have come down in price a lot:
http://www.ebay.com/sch/i.html?_from...bs&_sacat=3270
Old 10-05-2016, 08:09 PM   #499
BennyLava
Well its time to do an update on my unit, the main unit that this thread is about. And the one that the OP installed.
After 4 years, its done. The radio stations are starting to have static, and the bluetooth died about 2.5 years in. So while it was awesome at the time, its time for it to go. I'll be replacing it with the top of the line, $1,000 pioneer. Should be a hell of an upgrade, since the unit in this thread was a somewhat inexpensive chinese unit.
So my final analysis... Eh, you get what you pay for, and this radio was a roll of the dice. I wanted something that would last me 10 years, but got something that lasted 4. Based on the price, there are likely much better units out there. I'd probably avoid it.
Old 11-29-2016, 05:58 AM   #500
dazz
Drives: Vitz 1300cc 2007
Hi
My daughter has just brought a Japanese 2007 Vitz. The radio doesn't work well in my country.
There is no way she can afford a $1000 brand name head so I am looking at an Aliexpress Android. I brought one for my VW Polo and it works fine.
I see a number of heads which also include buttons on the facia surrounding the radio. Has anyone tried an Android 5.1 version of these? https://www.aliexpress.com/item/Quad-Core-optional-Android-4-4-4-Fit-TOYOTA-YARIS-2005-2006-2007-2008-2009-2010
dazz is offline   Reply With Quote
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 11:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Used Kenwood 7037 Double Din Touch Screen +10 Disc Changer ! micquek Items for Sale by private party 0 12-31-2009 09:31 AM
Getting ready to get a DOUBLE DIN touch screen player, NEED INPUT! Syroyizhka General Yaris / Vitz Discussion 12 04-08-2009 11:26 PM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 01:04 AM
