![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
Best way to stop belt from squealing at first startup?
I'm on my 3rd or 4th belt on my 2007 yaris with 125k miles on it. The problem i have is the belt squeals on cold starts. In the past i would keep tightening the belt, but then they eventually snap from the tension. Besides tightening, are there any other options to stop the belt from squealing on cold starts? Thanks
clean belt with belt dressing and toothbrush. also, overtightening belt will cause a squeal. needs to be at proper toughness. not loose, but not too tight. also check pulleys for binding/wore out-ness
Thanks for the reply....after researching a little more i found this posted in another thread here. I was skeptical at first, but this actually works.....no more squeal!!!
https://www.youtube.com/watch?v=HRrVMtyIqIY |
wow! that's a great video. I never knew. I always have started my cars slow. I usually let it sit in the "on" position for 3-5 seconds so the fuel pump primes and computer runs checks before starting. very interesting information here...
This worked for me too
The guy on the 'Carquestions' video is exactly right, I tried what he said and no more squeal. Simple, just hold at "run" for an extra second before turning the key all the way to start.
![]() ![]() ![]() Drives: Yaris T-Sport Join Date: Nov 2016
Keep belt tight enough and use only TOYOTA ORIGINAL !!!
#7 | |
Wife always starts right up, never had issues with her Honda for 14years.
My Echo actually did not like it once or twice, so I keep it a habit to wait a few seconds before starting. Not how you don't have a choice with push button start. :) Sent from my SM-G930W8 using Tapatalk |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Huh...ima have to try this.
Mine squeals often on start up. Nowhere near as bad in the video. Ive probably been thru 5 belts way sooner then needed. Ill have to pay attention how fast I turn the key
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| Easy fix for Squeaky / Squealing Belt | andrewmcg | DIY / Maintenance / Service | 44 | 06-04-2025 10:22 AM |
| New Serptine Belt Squealing | aaron21339 | DIY / Maintenance / Service | 11 | 10-14-2016 11:43 AM |
| squealing belt, but a different question | Yarflana | DIY / Maintenance / Service | 4 | 02-09-2014 12:41 PM |
| Squealing Belt Noise | Toyota3000 | DIY / Maintenance / Service | 3 | 07-23-2013 03:06 PM |
| Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 01:58 PM |
